P0171 DTCS code...troubleshooting help?
Old May 12, 2008 | 03:09 PM
EagleKeeper1026's Avatar
EagleKeeper1026
My CEL came opn, and the code for P0171 popped up, System too lean Bank 1. I know that my #1 Cylinder is running too lean, and I'd like to know what the most common causes for this code popping up are. I've heard it is quite possibly an O2 sensor, But I don't want to play parts swap-out-circus until I get the facts straight. Basically, whats the list of easiest/cheapest parts to look at first? If in fact it is an O2 sensor, which one would I swap out? Thanks for the help ahead of time!!
Old May 12, 2008 | 03:41 PM
pdqford's Avatar
pdqford
Just curious, but how did you determine that cyl #1 is lean? And is it the only lean cylinder on that bank?
Atta-boy! Diagnose the cause and fix the problem.
No. No! Diagnose the cause and fix the problem. Doesn't matter which parts are cheapest or easiest to replace - fix only the problem part.
The one that's causing the problem.
Of couse, I'm just josssing you. Let's start with the make, model, year, and engine.
Old May 12, 2008 | 04:13 PM
etewald's Avatar
etewald
He's got a 98 Gator. No idea on engine size though. My psychic abilities only go so far.
Old May 12, 2008 | 04:28 PM
EagleKeeper1026
haha sorry...98 Navigator with the 5.4 Triton...so how would i diagnose the exact problem?
EagleKeeper1026
Oh yeah, the ODBII reader said Bank 1.
Old May 12, 2008 | 04:33 PM
mastiff's Avatar
mastiff
i had the same error , cleaned the maf sensor at it went away. My engine was pinging under a load. After cleaning the sensor the pinging went away.
Old May 12, 2008 | 04:43 PM
73f100shortbed's Avatar
73f100shortbed
Check for vacuum leak. I believe pcv is on pass. side (Bank 1). Check the rubber hoses going from pcv to intake. Oxygen sensor is a last resort IMO. Vacuum leak is one of the most common problems causing P0171 and P0174. Cleaning MAF is also a good suggestion. Sometimes that throws both P0171 and P0174 though.
Old May 12, 2008 | 07:06 PM
eallanboggs's Avatar
eallanboggs
Maybe I don't know Fords well enough, but I thought Bank 1 was drivers side. I guess I work on too many GMs. If you already knew cy#1 was lean why didn't you solve that problem first? P0171 means Bank1 is lean. The O2 sensor doesn't know which or how many cylinders caused Bahnk 1 to go over the FTP standard, but the combined effect was enough to trigger the threshold value. You have to figure out if it's just cy#1 as you say or if there are other violators on Bank 1. Bank 2 is doing OK at this point so don't look for things in common to both banks like the MAP, IAT or MAF. What would cause cy#1 on Bank 1 to go lean and no others came along for the ride? Lean: Not enough fuel in ratio to the amount of air OR too much air in ratio to the amount of fuel. You're lean either way. Could you have a malfunctioning #1 injector(not enough fuel)? Could you have a vacuum leak(too much air)?
Old May 12, 2008 | 07:43 PM
EagleKeeper1026
Sorry about the misconception. I assumed bank1 was #1 Cylinder. I am new to working on these types of engines, and I just bought a Chilton's to start troubleshooting (I have no idea where anything is on this truck). I am going to check the vacuum hoses and PCV valve for now. What would I use to clean the MAF? Never had to do anything like this on my car (Stealth). Will check back soon. Thanks for the advice so far!
Old May 12, 2008 | 08:06 PM
EagleKeeper1026
PCV Valve and all hoses checked out good, no leaks that I can find. One thing I noted was there is a buzzing noise when the truck is turned off for about 25 seconds right in the middle of the engine somewhere. Any idea about this?
Old May 12, 2008 | 09:34 PM
sbclemens's Avatar
sbclemens
Originally Posted by eallanboggs
Maybe I don't know Fords well enough, but I thought Bank 1 was drivers side?
Bank one is the passenger side. Typically the front O2 sensor on that side is the first to let you know you have a problem so cleaning the MAF..etc and resetting the PMC would be a good start. How is the idle?
Old May 12, 2008 | 10:10 PM
EagleKeeper1026
Idle is good, MAF was a little dirty but cleaned it off, still has the CEL. do i need to reset the PCM manually, or should it go off on it's own when the problem has been fixed?
Old May 12, 2008 | 10:26 PM
73f100shortbed
Should clear the code. You can disconnect battery for a minute or reset with a code scanner.
Also most recently working on a 98 F150 it had a P0171 code and turned out to be a bad injector o-ring. Try spraying carb. cleaner on injectors on pass. side and see if idle changes. Don't know if this is your problem but worth a shot to try.
