Low Tire Pressure Sensor
Old May 12, 2008 | 07:08 PM
jamie120's Avatar
jamie120
I got new tires on the 2006 expedition and this light will not go off. Is there a trick to this? I reset it but it comes back on when we crank it back up again.
Old May 13, 2008 | 08:14 PM
Blu04XLT's Avatar
Blu04XLT
Assuming you kept the original rims and tire dealer replaced the original valve stem pressure sensors, you shouldn't have to do anything. I just got 4 tires on my 2004 XLT and Wal-Mart said they replace (rebuild) the valve stems' seals for $3.00 each. One of mine broke when they were removing it and it cost $49 for a replacement. Of course they said it was defective and they were not negligent. My low sensor light has not come on and I keep the pressure at 40 PSI year round. You might need to take it back to your tire installer and let them check the valve stems to be sure the gasket seals inside were replaced or not damaged / left off when re-installing.
Old May 14, 2008 | 08:12 AM
jamie120's Avatar
jamie120
low pressure sensor
Thanks for the help. It looks like there is nothing I can do quickly other than bring it back to the tire dealer and have them check the stems.
