timing adjustment
Old May 12, 2008 | 03:27 PM
meb9796's Avatar
meb9796
timing adjustment
Can't get my idle below 1800 without it stalling, so figured I'd check the timing, and it was advanced 30degrees. Now i realize it will go up some when the idle is up, but will it go up that much? and if so, is it possible to dial it back that far my rotating the distributor when I adjust the timing???
This is a 78 F-150 with 50K on a rebuilt engine. Just rebuilt the carb and trying to tune it and no luck getting it to idle below 1800 so far. Don't see any vac leaks and even checked it with a gauge.
Old May 12, 2008 | 03:35 PM
78f-150Supercab's Avatar
78f-150Supercab
Did you check the timing with the distributor vacuum advance disconnected and plugged? Is the dizzy Vac. Ad. connected to ported or manifold vacuum?
Old May 12, 2008 | 04:30 PM
montana_highboy's Avatar
montana_highboy
The fact that you just rebuilt your carb would lead me to believe something is a miss there, i'm assuming you didn't mess with your timing during the carb rebuild, 30 degrees of advance @1,800 rpm's is nothing to be alarmed about because at 1,800 rpm's you're also reading vacuum and centrifugal advance as well as initial.
Old May 12, 2008 | 06:00 PM
meb9796's Avatar
meb9796
Hey guys, thanks for the quick responses. First the vac advance is connected to manifold vacuum and yes, I did have it disconnected from the distributor when I checked the timing. I also capped off the advance vacuum port on the distributor.
Also, I had the gauge connected to the port on the vac advance and it showed no vacuum. I was using the hose that is normally connected to the vac advance, and noticed that there was a metal sleeve on the vac advance side.
If the vac advance was disconnected then I shouldn't have been seeing 30 degrees of advance should I????
Old May 12, 2008 | 06:30 PM
montana_highboy
Keep in mind you're reading this with the engine idling at 1,800 rpm's, so it depends where your initial is set and how your distributer is curved, most stock distributers have all their advance in well before 3,000 rpm, so if your total advance is 36-38 degrees and all in around the 2,500 to 3,000 rpm range then 30 degrees of advance @1,800 rpm is to be expected.
Old May 12, 2008 | 07:49 PM
meb9796's Avatar
meb9796
ok, that makes sense, thanks for explaining it. Mine has a total advance of 30 degrees, and it was hovering between that and 'BTC'.
Darn! I was hoping I could dial that back and fix my idle problem. But I think you're right about my rebuilt carb, I just didn't want to admit defeat so easily...wouldn't believe the hassle it was to rebuild that thing. Guess I gotta go figure out who in VA gets my money to rebuild the carb.
Old May 12, 2008 | 09:35 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
You want PORTED vacuum from the carb and not MANIFOLD vacuum from the intake for the Vacuum Advance on the distributor.
Old May 12, 2008 | 10:06 PM
Alvin in AZ's Avatar
Alvin in AZ
Whenever the gang would work on my district I could count on some overtime! :)
It's just the way it is, even if the fault couldn't be directly related to the guys working on it, them just out there messing with stuff could disturb something that was working, but maybe -just barely- but was working.
Could you tell us which model carburetor you're working on?
I've always been into carburetors and modifying them is an interest of mine. :)
Alvin in AZ
Old May 14, 2008 | 07:43 PM
meb9796's Avatar
meb9796
It's a motorcraft 2150. I'm almost at the point where I want to put a holley carb on, but I'm not sure if the connections will work.
Old May 14, 2008 | 07:50 PM
meb9796's Avatar
meb9796
ported vac from the carb? There is only one vacuum connection coming off the rear of the 2150 carb, and it's connected to a tree vacuum connection on the rear of the manifold. It was that way when I got the truck, but I'll check it out tomorrow night.
Old May 14, 2008 | 10:40 PM
4x4 Bart's Avatar
4x4 Bart
The motorcraft 2150 is a good carb, easy to rebuild and when it's right,will perform equal to holley of same size and less finicky.
jbwolfe
13
Dec 1, 2012 10:57 PM
meb9796
May 28, 2008 12:04 PM
ferreed
17
Mar 1, 2004 08:36 AM
thelonerangerxlt
Oct 9, 2003 07:54 PM
56mercury
Jun 11, 2002 07:47 PM
