back up lights/front springs
Old May 12, 2008 | 12:11 PM
claytonandson's Avatar
claytonandson
2 questions....
1. what would cause my back up lights to not work,after checking fuses and bulbs(ok)?
2. if i want to make up for the heavy pre-runner bumper i currently have installed,should i go with a set of HD springs,or do they make spacers like on my jeep?
Old May 12, 2008 | 12:22 PM
gweeds's Avatar
gweeds
Are they leaf springs or coil springs?
Old May 12, 2008 | 06:43 PM
claytonandson
96 f150-xlt w/coil fronts
Old May 13, 2008 | 05:57 AM
alz's Avatar
alz
Alot of people on here are going with F350 2wd coils. Could also go with a leveling or 2in lift coil.
Old May 13, 2008 | 10:11 AM
claytonandson
any suggestions regarding the back uplights????
Old May 13, 2008 | 02:44 PM
adrianspeeder's Avatar
adrianspeeder
What kind of tranny do you have?
Adrianspeeder
Old May 13, 2008 | 03:20 PM
alz's Avatar
alz
If it's an auto, the linkage may be a little off or loose. I've seen many vehicles were the backup lights go on when in neutral.
Old May 25, 2008 | 09:39 AM
claytonandson
it an automatic......
Old May 25, 2008 | 10:34 AM
Animalistic's Avatar
Animalistic
F-350 coils would probably be your best and cheapest route. Make sure you have it aligned after the swap. For the lights, you should have a plug on the trans. for them. It may have come unplugged or got gunk in it. On my C-6, it is the only electrical but you will have more with a newer rig and trans. Take a look at the connections and see if they have power when moving the shift lever. Unfortunately, I am not sure which connection it is down there but it should be on the side by the shift linkage.
Old May 25, 2008 | 10:42 AM
BChance's Avatar
BChance
You can check fuse #5, (15 amp), your park/nuetral position switch, or trace the black/pink wire back from the lights to the switch.
The PNP switch is located right above the shift linkage, drivers side, goes straight down in if it's a AOD, on an E4OD it's called a Manual Lever position Sensor, and it is mounted on the manual lever shaft..on a C6 it is called a Nuetral Safety/Backup Light Switch, and is also on the manual lever shaft.
The E4OD and the AOD have specific adjustments, and if I remember right, the AOD requires a 3 prong tool to align it.
All that said, check the sockets for the bulbs for power first..use a test light. THEN check the fuse, THEN check for power at the switch, THEN check power out of the switch AT the switch.
