help or hurt
Old May 12, 2008 | 06:17 AM
hillbilly1025's Avatar
hillbilly1025
help or hurt
hey guys i'm again in need of your infinate wisdom. I have a '02 ranger 4x4 w/ 4.0 (sohc) auto 4.10 gears, currently running the factory tires 245/75/16 at 70mph the tach reads around 2600 rpm . I think this is alittle high w/ an OD tranny, but I'm usually wrong. I'm taking this week to get the tranny fluid changed and they have a fuel sys cleaner thats supposed to be good. Has anybody done this fuel treatment, did it help? And the bigger question I had, was Ihave a chance to buy a set of 285/75/16 for a cheap price, will the bigger tires help lower the gear ratio (virtually, i know it wont really change it), threfore making my gas mileage better? thanks in advance for any help.
Old May 12, 2008 | 08:00 AM
crazypaw's Avatar
crazypaw
Wink tires
Hi hillbilly1025,
245/75/16 to 285/75/16 = just fatter tires = more friction = less milage!
How much less milage??
Old May 12, 2008 | 09:38 AM
5.0B2's Avatar
5.0B2
Sorry Bear Paw - fatter and taller
245's - 30.5" tall 9.6" tread width
285's - 32.8" tall 11.2" tread width
Whether the 1.15 inches of additional sidewall height will help or hinder mileage----
Old May 12, 2008 | 09:39 AM
5.0B2's Avatar
5.0B2
Oops!
Sorry about that Bear Paw Crazy Paw.
Old May 12, 2008 | 09:44 AM
5.0B2's Avatar
5.0B2
Hillbilly - the 285's will make your speedometer read about 5 mph low at an indicated 65 mph and about 2 mph low at an indicated 25 mph. Unless you can re-calibrate it.
Old May 12, 2008 | 12:34 PM
wendell borror's Avatar
wendell borror
Yeah it will change the gear ratio, but because the tires are bigger and heavier, it won't help the mpg. I ran 265/75-16's on my 04 4x4, they worked really well, looked good and didn't seem to effect the mpg that I could tell.
Old May 14, 2008 | 06:07 AM
hillbilly1025
thanx for the replies, that was pretty quick. your probably right about the 285's, now i got a line on some 255/85/16 they are 33x10x16 if i'm not mistaken, so the friction shouldn't change much right? has anyone got any suggestions on the "Jiffy Lube" type fuel injection system cleanings?
70_F250_390
Oct 24, 2011 04:25 PM
BCHauler
Oct 27, 2010 02:00 PM
nstueve
Feb 12, 2010 04:12 PM
SMB
Feb 13, 2004 08:45 PM
will-work -for-mud
1997 - 2003 F150
13
Sep 16, 2003 07:21 PM
