2004+ stake pocket templates- cut thru cap
Old 05-11-2008, 03:15 PM
Truck2Board's Avatar
Truck2Board
Truck2Board is offline
Anyone know a good template for cutting the plastic cap to access the stake pockets?
If not, will try the dealer...
Also - anyone with experience placing stuff in the '04+'s pockets - Expect them to be hurky enough for just about anything, but can't find anything here...
Thanks!
Old 05-11-2008, 04:20 PM
Twinsdad98's Avatar
Twinsdad98
Twinsdad98 is offline
The caps pop right off, so when I had to cut mine for my bed rails, I just popped them off and made the cuts. Can't remember, but I seem to recall a slight outline from the underside. You could also get a trim bit and just cut the holes in place if you have some thing like that.
Old 05-11-2008, 06:32 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
pry the bed caps off, then apply some axle grease to the top of the bed around each bed stake. put the bed cap back on. remove
you should have a fairly perfect outline of the stake pocket
Live4darumble
2015 - 2020 F150
10-24-2017 10:18 PM
dadgonebroke
17
01-06-2017 02:02 PM
moose79
16
01-12-2016 09:41 PM
Skalywag
06-03-2015 11:02 AM
greythorn3
Paint & Bodywork
03-02-2008 07:22 AM
Quick Reply: 2004+ stake pocket templates- cut thru cap
