Yet another synth oil question
Old May 11, 2008 | 02:35 PM
squaredancer's Avatar
squaredancer
Getting ready to install the Oil Guard Bypass filter kit and then switching to synth oil. Reading a bunch of threads on synth oil ,the older ones mention that one has to add a quart every x amount of miles as the engine runs thru it faster or burns it faster ? Or is this related to the leaking gasket issue that synth had when it first came on the market ?
Old May 11, 2008 | 05:17 PM
UP_There's Avatar
UP_There
your engine will burn/leak the same amount of oil regardless of it it is dino or synthetic.....synthetic is muuuuuch better for your motor, easier starts, smoother idle, and in some cases even a little better mpg. Definitely helped my truck
Old May 11, 2008 | 05:41 PM
white Buffalo's Avatar
white Buffalo
YOur engine won't require any more fill/add oil than it normally does. I've been running syntheics in various applications for @ 12 years.
You will like the oilguard bypass system, it takes about an additional quart to fill with the extra filter & lines but I have run it for over 2 years and I am happy with the results.
Old May 11, 2008 | 05:51 PM
clintbonnie's Avatar
clintbonnie
I agree with Rich and Travis.. you won't notice much difference on oil consumption or oil leaks... but your engine will like it..
