replacing timing cover, gasket problem
Old May 10, 2008 | 09:22 PM
mike L's Avatar
mike L
I have the blue flepro oil pan gasket with metal inside. What should i do, i cant cut it like the gasket set says to do.
Old May 11, 2008 | 08:26 AM
EPNCSU2006's Avatar
EPNCSU2006
I would leave it alone. Just clean it and be careful to get it in the groove in the bottom of the timing cover when you reassemble. I definitely would not cut or try to cut it. Does the rubber still seem soft and pliable, or is it hard and compressed?
Old May 11, 2008 | 12:36 PM
mike L's Avatar
mike L
broken oil pan gasket, adding timing chain
The oil pan gasket broke on the front of the oil pan, where there is no metal. Can I use gasket sealer on the oil pan. Or will i have to add a new oil pan gasket?
Frankmyers
Feb 10, 2015 09:49 AM
Robrt32
Feb 19, 2014 06:43 PM
bruno2
Jun 8, 2012 11:56 AM
FordNFishinLover
Oil & Lubrication
Apr 23, 2009 08:12 AM
frankster123
Mar 31, 2003 06:00 PM
