Hello and welcome to the site. Fresh imput is always welcome.
Here is a link to a post with the fuseable links. I will do some more looking for the fuse box picture for you. I just remember this post from yesterday so I was able to find it for you. What kind of issue are you having?
I'm not really having any issues but while messing with my trailer lights I came across a fusible like that was broken/burn up and although I do need to replace it, I was curious what it was for.
The pictures in the above link should point you in the right direction. I did a quick search and did not find a picture of the fuse box but I know there is one out there. If someone hasn't pointed you in the right direction later, I will scan it in myself. Just don't have access to it now.
Select the top sticky post "Read First: 1987 to 1996 Tech info " and go to the electrical section. I believe you will find what you are looking for there. Good luck.
