squeaking brakes
Old May 9, 2008 | 02:50 PM
JIMS 71's Avatar
JIMS 71
squeaking brakes
Man these brakes are driving me nuts. 71F250/cs. dual piston calipers. I start out everythings ok, brakes cold. They start squeaking about the second or third stop sign (brakes warm) with just a touch of the pedal, if I mash down it goes away then returns as I let up. What am I missing? Put new rotors, calapers, bearings, pads everything new. I've pulled the pads, sanded them, no change. Did I leave something off???????? thanks,jim
Old May 9, 2008 | 06:10 PM
jowilker's Avatar
jowilker
There are some "anti" parts or stuff that you squeeze on with some brake kits for noise. Did your set not come with it???
John
Old May 9, 2008 | 06:25 PM
JIMS 71's Avatar
JIMS 71
Nothing but calipers and pads in one box. I'm thinking might try different pads. These work fine, just noisy. I hear bearing grease on rotors works really well. High temp of course.
Old May 9, 2008 | 10:24 PM
4x4 Bart's Avatar
4x4 Bart
At the auto parts store you can buy a special tube of Anti-squeal gel that you coat the backs of the pads where they touch the piston or caliper. Put lots on,the more the better. This prevents the pads from vibrating. This works about 90% of the time.
Old May 9, 2008 | 10:54 PM
Red69's Avatar
Red69
The lifetime warranty pads are loaded with metal particals to give long wear. They also squeel. The less expensive pads won't last as long, but because they are softer they are less noisey.
Old May 10, 2008 | 01:28 AM
jhooch's Avatar
jhooch
4X4 Bart hit the nail on the head. Disc-brake anti-squeal on all metal parts that touch. Your semi-met pads are not the problem. Also make sure none off your anti-rattle clips are touching the rotor. Good luck.
Old May 10, 2008 | 10:11 AM
JIMS 71's Avatar
JIMS 71
Thanks all, I'll try the grease first, pads last resort.
Old May 10, 2008 | 08:45 PM
68horses's Avatar
68horses
BEARING GREASE ON THE ROTORS?!?!?
I thought you were making a joke when you first mentioned that.DO NOT put grease on your rotors,it will ruin your pads,maybe the rotors and cause all sorts of issues.
Gene
Old May 11, 2008 | 05:55 AM
jowilker's Avatar
jowilker
Fellows, Yall got me scratching my head a bit, where did grease and or bearing grease come from? The material that I was referring to is not a lube, but a sound deadening material that has come with some brake sets that I have used.
John
Old May 11, 2008 | 07:10 AM
Red69's Avatar
Red69
JIMS71 said,
"Nothing but calipers and pads in one box. I'm thinking might try different pads. These work fine, just noisy. I hear bearing grease on rotors works really well. High temp of course."
Old May 11, 2008 | 07:24 AM
Danger_Dave's Avatar
Danger_Dave
the only place i ever put the lube or bearing grease at is on the pins that the pads slide along. those are the part that always makes the squeaking. every time i change the pads i sand those pins with 2000 grit or steel wool and then grease them.
Old May 11, 2008 | 09:50 AM
JIMS 71's Avatar
JIMS 71
Easy does it, it's a joke????????
Old May 11, 2008 | 12:03 PM
jhooch's Avatar
jhooch
Permatex makes an actual silicone based disk brake lubricant available at most auto parts stores. We use it at work extensively and it works great. Apply to backing of pads and the pins, sliders, etc.
Old May 11, 2008 | 12:45 PM
Byteme's Avatar
Byteme
I bought the 10 dollar can from CRC at Autozone, same basic thing, and I agree, it works better than the little packs they have at the counter, and once you buy a can, you're set for life. Not really, but a can will last for a very long time.
W7PSK
6.7L Power Stroke Diesel
Jun 30, 2017 01:51 PM
jim20j
Escape & Escape Hybrid
Jul 17, 2012 03:58 AM
F 250 6 liter
Sep 16, 2010 07:49 AM
spdmpo
13
May 28, 2010 10:17 PM
zippinz
Aftermarket Products
Aug 5, 2002 08:56 AM
