06 Blower *High Only*
Old May 8, 2008 | 09:39 PM
ShaneWdrd's Avatar
ShaneWdrd
Hi all,
Got an 06 Tremor and the A/C blower is stuck on high. Got it used and of course it had no owners manual.
Can anyone tell me where the solenoid is so I can swap it out and see if that solves it.
Any one have any ideas. I do get a gurgling sound when I turn it on like its on the vaccum side, which I hope thats not the case.
Old May 9, 2008 | 12:56 AM
camodown's Avatar
camodown
The blower motor resistor is to the left of the evaporator housing, right below the circular blower motor. It's a resistor that defaults to hi only when it goes south. Easy to change. Not sure on gurgling
Old May 9, 2008 | 04:40 AM
pgw85706's Avatar
pgw85706
Agree, check the blower motor resistor. Several threads on this topic in the forum if you want to search. The part is about $15.
https://www.ford-trucks.com/forums/4...96-ranger.html
Old May 9, 2008 | 06:14 AM
Dan Robertson's Avatar
Dan Robertson
My 98 Ranger had a similar problem. It had only the lowest and highest fan speed. I bought a new resistor but the problem came back in just a few weeks. It ended up being a bad wiring harness. Good luck.
Old May 9, 2008 | 09:31 AM
pawpaw's Avatar
pawpaw
I agree, it sounds like the blower motor speed resistor pack. Seeing as how this is an 06 model, it's still likely under warranty, so make it Fords problem & let them fix it.
You can down load a owners manual here.
http://www.fleet.ford.com/maintenanc...ls/default.asp
Old May 9, 2008 | 11:44 AM
Pablo-UA's Avatar
Pablo-UA
Sometimes resistor terminals are toasted. Check them frst. I had one contact bad and had no blowing exept of on high
Old May 9, 2008 | 07:14 PM
ShaneWdrd's Avatar
ShaneWdrd
I'm not too engine savy but I just pulled the harness out through the firewall and took off all the coorigated tubing and I don't see a single resistor.
There is a splice orange/black that goes to the blower motor but no resistor.
Is the resistor on the second part of the harness in the vehicle?
Old May 9, 2008 | 07:21 PM
87 XLT's Avatar
87 XLT
The resistor will be plugged into the plastic heater duct with 4 or 5 wires attached.. The air blowing across it helps keep it cool. One or 2 small screws holds it in place
On my 87 Ranger, it's under the hood.
On my 95 Taurus, it's under the dash.
Old May 9, 2008 | 08:14 PM
87 XLT's Avatar
87 XLT
One other thought, the blower resistor is about the size of a credit card, and like I said it plugs into a hole in the plastic heater/AC duct, but I have no idea where on an 06.
This has manual controls?? Not auto climate?
Old May 9, 2008 | 08:27 PM
ShaneWdrd's Avatar
ShaneWdrd
Yeah manual controls. The credit card thing helps a lot... I'm thinking an in line resistor on a wire.
Old May 9, 2008 | 08:33 PM
ShaneWdrd's Avatar
ShaneWdrd
Great.... Just went out there and found it. Right between the evaporator and blower like the first guy said. The whole two screws and credit card shape makes perfect sense now.
Will Autozone have something like this or should I shoot by the Ford Dealership?
Old May 9, 2008 | 08:39 PM
87 XLT's Avatar
87 XLT
Good deal, glad you found it.
Any parts store shpuld have it- but call first- the last one I replaced was on my neighbors 96 Contour,
Strangely enough Napa & Autozone did'nt have it. It was 24 bucks at the dealer.
Old May 10, 2008 | 04:47 AM
pgw85706's Avatar
pgw85706
It's an 06....shouldn't warranty cover this repair?
Old May 10, 2008 | 03:20 PM
ShaneWdrd's Avatar
ShaneWdrd
Bought it used and I think it only have a 30K warrenty and it now has 35K.
It's not available to Autozone or Oriely's yet - to new. But I called the dealer and its only $25 so I will pick it up on Monday.
Old May 10, 2008 | 08:09 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
The warranty is 3 years or 36,000 miles from the time it was originally bought new. The new vehicle warranty is also transferable, which means that even though you bought it used, the warranty still applies (with a few exceptions, including Salvage titles).
While you're at the dealer have them run an OASIS check on your VIN, and they will tell you if you're still under warranty or not.
