Help!!!!
Old May 8, 2008 | 09:21 PM
AzSlugger's Avatar
AzSlugger
Help!!!!
Help I have a motocrap 2bbl on my 73 f-100 all stock 390 when I drop it into gear she wants to sputter and stall without warning at idle runs great but put a load on and forget it what is wrong with this thing?
Old May 8, 2008 | 10:14 PM
LxMan1's Avatar
LxMan1
You have a lean condition most likely. Look for a bad vacuum line. If none, try backing out the mixture screws a little to see if it improves.
Old May 8, 2008 | 10:31 PM
AzSlugger's Avatar
AzSlugger
Checked for vacuum issue already found none all new lines, adjusted carb definitely not a rich/ lean condition. It only happens when I put it into gear at idle when moving runs like a top could this be a timing issue? I am almost at my wits end.
Old May 10, 2008 | 03:27 AM
AzSlugger's Avatar
AzSlugger
Yaaa for me I fixed the blasted thing timing was way off and points were fried.
Old May 10, 2008 | 07:24 AM
LxMan1's Avatar
LxMan1
That'll do it. Glad you figured it out.
