6.0 intercooler
Old May 8, 2008 | 08:37 PM
bruce51d's Avatar
bruce51d
6.0 intercooler
for the people who have already done the swap did you use the boot kit from dieselsite or is there another way around buyin their kit and maybe savin some money. any help is appreciated
Old May 8, 2008 | 09:18 PM
Pocket's Avatar
Pocket
I had the Dieselsite boots before buying the 6.0L I/C. The driver's side didn't fit at all, and the passenger's side wasn't long enough to hold very well.
Here's a link to boots that will fit. Don't forget you'll need a new 3" boot clamp, since the 6.0L inlet is smaller than the stock 7.3L I/C. Boots you'll need are 3x3x8" and 3x3.25x8". Ford 7.3L Powerstroke Diesel Spearco Intercoolers Intercooler Boots
Old May 8, 2008 | 09:26 PM
a-rod's Avatar
a-rod
I actually went to a hose and rubber place and got some heavy duty 3 inch hose, It was a pita getting it over the passenger side, but I was able to stretch it over with some heat and lube.
Old May 8, 2008 | 09:27 PM
jhand124's Avatar
jhand124
Curtis, that was a really good and informative response, reps to you. This is totally have you put your truck on the dyno yet? Looks like you are still on stock sticks, is that your next mod?
Old May 8, 2008 | 09:44 PM
jkidd_39's Avatar
jkidd_39
Awesome Info Pocket!! I was just gonna ask this. Also what is considered bad damage for these intercoolers. The 6.0 I am gonna pick up has about a 1/2 ding on the fins.
This alright?
$125 sound reasonable?
Old May 8, 2008 | 09:46 PM
Pocket's Avatar
Pocket
Nah, hasn't been on the dyno. According to my weight and 1/4 mile times, I'm around 350'ish hp. As for the injectors, they are staying until they die. Any upgrades I do usually ends up as overkill, and the PMR's won't handle the power I want. Unfortunately, the mod budget has been spent for now. Money is going elsewhere for the time being.
Old May 8, 2008 | 09:48 PM
Pocket's Avatar
Pocket
This alright?
As long as it holds pressure, it should be fine. Mine was $180 brand new in the box, but it had a slight ding on the bottom thanks to UPS. Still works and doesn't leak, and I've had it in there for over a year now.
jhand124's Avatar
jhand124
350'ish is pretty good for a PSD, nice lookin truck.
Old May 8, 2008 | 09:49 PM
jkidd_39's Avatar
jkidd_39
How would one pressure test an intercooler without installing it?
Old May 8, 2008 | 09:55 PM
Pocket's Avatar
Pocket
Air compressor and some way to cap it off. You can find parts at Home Depot that you could fit together.
