360 Compression #'s, now what?
Old May 8, 2008 | 10:03 AM
ramarado's Avatar
ramarado
Ran a compression check on my 73, 360 this morning. Of course the engine is cold as the cam gear is stripped but trying to decide how far to go at this time. The #'s are:
1. 140
2. 140
3. 100, after sqirting a little oil from can 112
4. 98. after squirting a little oil from can 102
5. 138
6. 140
7. 132
8. 132
After doing 5-8, I went back to 3 & 4 and ran them again without any more oil and they were 3-120 and 4-115.
Now that being said, I really don't want to do a complete overhaul at this time, as I want to build a 390 over time and need this truck running in the process. Could it be a head gasket between 3-4? I don't seem to show any of the typical signs of a Hg but don't know.
This engine is very nasty inside. I'm thinking about pulling the heads, checking valves on those 2 cyl, replace head gasket and cam and go. Also isn't 140 a little high for a 360?
Just need some re-assurance I suppose.
Old May 8, 2008 | 11:16 AM
Redmanbob's Avatar
Redmanbob
a leak down or a poor mans leak down would confirm the HG between cyl or valve related comp loss or other..
Old May 8, 2008 | 08:57 PM
Tedybear's Avatar
Tedybear
Just by a fast checking on the numbers I'm leaning towards the start of a head gasket issue. However as Red stated? A leak down test would give you the exact answer, and save some headache. If you have access to an air compressor? Pick up a fitting/adapter for this purpose. Put the cylinder(s) in question at TDC and ensure both valves are closed. (visually check with the valve cover off).
Air charge the cylinder(s) and listen/feel where the air is leaking. If it's a head gasket? You'll feel air escaping from the spark plug hole next door. Intake/exhaust valve issue? Check air flow at tailpipe or coming out of the intake/carb if still installed.
S-
Old May 8, 2008 | 09:21 PM
ramarado's Avatar
ramarado
Thanks guys.
Already have the rocker arm assem. off both sides, along with intake, (whewh, that's one heavy momma by ya self!), but may try the leak down test. I don't know though, the motor is sooooo internally nasty, I feel like I'll pull the heads and clean 'em up and put valve seals on at least, (from what I see there aren't any, or they are riding the valve) thus getting new head gaskets anyway. I do know the oil passage leading throught the head to the valley where the rockers is completely stopped up with crud.
Old May 8, 2008 | 09:43 PM
Redmanbob's Avatar
Redmanbob
and so it begins....................
Old May 8, 2008 | 10:12 PM
ramarado's Avatar
ramarado
Yeah, I knew my luck would run out eventually. This ole thing sat for so long and was running so good, especially after the timing chain, I couldn't believe it! Was getting 13.8-14 MPG and ran smooth, but freshening up and a few minor mods, Pertronix, new dist., new cam & lifters, and if I can find a 4bbl carb cheap shouldn't hurt. I have a S code manifold that will go back if I find a carb in time. Just haven't found any headers that I can afford right now.
Old May 8, 2008 | 10:17 PM
ramarado's Avatar
ramarado
Anyway the Pres. Bush wanted the economy stimulated and I wanted the truck stimulated so maybe we'll both be happy. Speaking of stimulatin' "where's my wife?"
Christopher Layton
Apr 13, 2016 02:34 PM
89302
Nov 14, 2015 01:48 AM
my-ford
Jun 2, 2015 10:53 PM
Mister_King
13
Feb 25, 2015 09:41 AM
