are these good compression readings?
Old 04-12-2016, 05:01 PM
Christopher Layton
Christopher Layton is offline
Christopher Layton is starting off with a positive reputation.
Just ran a dry compression test after warming up the engine (trying to troubleshoot why it idles a little rough)
1990 F350 7.5L (460) FI
Are these considered good readings?
Cylinder
1: 140
2: 139
3: 140
4: 139
5: 140
6: 145
7: 145
8: 150
Old 04-12-2016, 05:36 PM
bmxerbrett's Avatar
bmxerbrett
bmxerbrett is offline
bmxerbrett is starting off with a positive reputation.
Those all look good to me. You can check the rings by putting a small amount of oil in each cylinder through the spark plug and recheck compression. If it shoots up the rings are worn.
Old 04-12-2016, 11:39 PM
82F100SWB's Avatar
82F100SWB
82F100SWB is offline
82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.
You are well within the 10% variance that is considered good and those numbers are pretty decent for a stock engine.
Old 04-13-2016, 12:03 PM
Christopher Layton
As it turns out the problem wasn't the engine misfiring causing the vibration, it was the fan clutch that had gone out and the fan was vibrating heavily because it was not centered anymore due to the clutch being messed up. Picked up a new fan clutch from Autozone for $35 and the problem is solved. Runs perfect.
Old 04-13-2016, 01:57 PM
justcruzin125
justcruzin125 is offline
justcruzin125 is gaining momentum as a positive member of FTE.
Cylinder
1: 140
2: 139
3: 140
4: 139
5: 140
6: 145
7: 145
8: 150
How many miles are on your truck?
Old 04-13-2016, 02:34 PM
Christopher Layton
106,957 miles
SSStang
15
10-12-2017 01:16 PM
BeauF0RD
05-02-2017 06:53 AM
F1Hunter
03-13-2017 03:58 AM
TruckerATK
10-04-2016 04:31 PM
GuitarJesus
05-05-2016 07:28 PM
Quick Reply: are these good compression readings?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
