I have just started bringing a 1961 F100 Stepside back to life, I am looking for the door widow glass channel for strike side, I bought anti-rattle kit but it doese not include the steel u channel for strike side. I have 1 but other was missing, Any sources ??
Which side do you need? I have 2 extra doors, will send you 1 if you like.
Bill, I need the channel that is inside door, strike side, if you have one let me know, They appear to fit either door. Its about 2-3 feet long u channel attached with 3 screws, that holds window guide felt. You can email me at , Thanks
the metal channel thats held in by those screws isnt the felt rear glass run...that channel is a steel U channel the lower portion of the rear glass run pops into.
The p/n for the steel channel is C1TZ81222A01A LH
C1TZ81222A00A RH
both can be found readily NOS if you want one...which side are you in need of ???
Green Sales has 8 of the LH and 81 of the RH ones...
I received the neded channel from Bill, Thanks again, I have posted pics in album. Tracks were easy to install, 3 screws. The window seal kit I got form LMC I would rate as OK, but not great on fit, Of course it was my first time.
