Sponsored by: Real Truck
Changing Headlights
Old May 6, 2008 | 09:47 PM
Docdor's Avatar
Docdor
Changing Headlights
I've got a 2004 F-350 6.0 with dual batteries. Has anybody changed the headlight (bulbs) in them yet. Looks like they were born in there. Thanks
Old May 6, 2008 | 10:41 PM
thedaddycat's Avatar
thedaddycat
I have the '03 version and I have replaced the bulbs with Silverstar Ultras. It is kind of a PITA if you have big hands. One thing to remember is that you can unplug the harness, then turn the black collar or ring and remove the bulb. Put the new bulb in, then put the collar on and then plug it back in. I tried to do it with the bulb plugged into the harness and the collar hanging on the wire, not very fun at all......
Next time I will just tell my 10 year old to do it, she can reach right down in there no problem.........
Old May 7, 2008 | 10:18 AM
ffadragon's Avatar
ffadragon
Can you tell abig difference in the Silverstars compared to the OEM bulbs?
Old May 7, 2008 | 08:38 PM
Docdor's Avatar
Docdor
Hey thedaddycat did you have to pull the batteries for hand room??
Old May 7, 2008 | 09:59 PM
thedaddycat
The Silverstar Ultras are whiter and brighter than the Sylvanias that were in there. From all I've read that will only improve with the addition of a heavy duty harness like the Dfuser one. I did not remove the batteries, part of the problem with getting my hands in there to be sure. I did it in the parking lot of Pep Boys as soon as I bought the lights so I could try them out on the way home from work. The only thing is that I'd like to update to the '05 front clip which means new headlight housings which will take different bulbs. Maybe these will fit the wife's Freestyle, I'll have to check that out once I get the update done. That's one reason why I have not added the HD harness yet.......
gmeff
1997 - 2003 F150
Mar 10, 2010 06:53 PM
warpaint
Feb 25, 2009 09:56 AM
randomhero1172
Feb 24, 2008 09:29 PM
77_f250_460
Paint & Bodywork
Dec 5, 2001 08:22 PM
