Started the assembling process!
Old May 6, 2008 | 05:28 PM
Aussie 53's Avatar
Aussie 53
Started putting things back on the chassis now. Taken two picks and you can see two different contrast of the colour under different light.
Old May 6, 2008 | 06:28 PM
49willard's Avatar
49willard
It's got to feel good going back together. I also checked out your gallery. A bit more work putting the Jag in the wider F100 front frame rails but it looks real good.
Congrats!
Old May 6, 2008 | 08:04 PM
seaves46's Avatar
seaves46
Congrats!
There is absolutely no reason to have to alter the rails the way aussie 53 has done it . For some reason he has mounted the jag f/e very low under the chassis with a large gap between the chassis and f/e. A better way to mount it is to mount it solid without the rubber mounts it will get your truck about 2 inches lower and no need to go hacking at your chassis.
