need to no
Old May 6, 2008 | 04:17 PM
hunterkane's Avatar
hunterkane
need to no
if the inner fenders and radiator support for 1973 - 1979 f-100 are the same as 67 to 72 thanks
Old May 6, 2008 | 08:35 PM
Freightrain's Avatar
Freightrain
You can use them, if you use both the support and inners, but I don't think you can mix/match them. Seems I've seen other guys switch them over as the newer pieces are galvanized and will survive better.
Old May 6, 2008 | 08:54 PM
hunterkane's Avatar
hunterkane
going to ty and trade for inners and support
Old May 6, 2008 | 10:25 PM
7283-F250's Avatar
7283-F250
I read somewhere that you can add a few bolt holes to use the 67-72 inners.
I piece mailed a 75 onto my 72. I took one of the mounting brackets (frame mount) off the 75 to replace the rusted out bracket on the 72. Not an exact match but it worked. Mount hole in the same place but now the left and right side mounts look slightly different.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
