fuel problems
Old May 6, 2008 | 01:42 AM
iduger's Avatar
iduger
fuel problems
Gas is dripping into carb from center jet when running. Any cures? 1 bbl carb.
Old May 6, 2008 | 02:42 AM
fmc400's Avatar
fmc400
MSEE
Too much fuel passing through the metering system. Two possibile causes: float level set excessively high, or debris is caught in the float seat and needle valve. If the carb just started doing this all of a sudden, it's likely the second case and it's getting time for a carb rebuild. If the carb started doing this after a rebuild, you need to re-adjust the float.
Old May 6, 2008 | 05:06 PM
iduger's Avatar
iduger
Thanks for the help!
