Fuel Tank Question
Old May 5, 2008 | 08:36 PM
PAVEMENTMAN's Avatar
PAVEMENTMAN
Fuel Tank Question
I Have A 96 Psd And It Has 2 Tanks And Was Wondering If The Front And Rear Tank Holds The Same Amount Of Fuel.
Old May 5, 2008 | 08:41 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Been a while since I've had a two tank truck, but IIRC the front is 17 gal. and the rear 19.
Old May 5, 2008 | 08:47 PM
okfarrier's Avatar
okfarrier
Cookie is right on,or at least within half a gallon.
Old May 5, 2008 | 09:01 PM
PAVEMENTMAN
Ok Thanks Guys.
Old May 5, 2008 | 09:36 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
1996 Ford Truck Source Book
FUEL TANK -- (Dual tanks)
Reg cab 4x4 PSD has 40.2 gals. - Front 22.0 gal Rear 18.2 gal
Super Cab 2x4 or 4x4 PSD SWB 34.7 gals - Front 16.5 gal Rear 18.2gal
Super Cab 2x4 or 4x4 PSD LWB 37.2 gals - Front 19.5 gal Rear 18.2gal
CC 2x4 or 4x4 PSD Same as Super Cab SWB or LWB
Old May 6, 2008 | 08:08 AM
plowhand's Avatar
plowhand
Playing in the Dirt
Good info, tried to rep you but I gotta spread the love around.
Old May 6, 2008 | 08:20 AM
phillips91's Avatar
phillips91
--1996 Ford Truck Source Book
are you all sure about this?? could the 97 have different tanks than the 96?? ive got a 97 reg cab 4x4 with dual tanks and i cant get anywhere near that amount in mine. i ran the rear tank to empty and could only get 15 gallons in it. did the same for the front tank and could only get 19 gallons in it. and its been like that every time i fill up. assuming the filler neck will hold one gallon, im looking at about an 18 gallong tank on the front and a 14 gallon in the rear.
Old May 6, 2008 | 09:16 AM
Cuda_jim's Avatar
Cuda_jim
Right from the Horses mouth, 1996 & 1997 Ford Repair Manual:
All of the rear tanks (plastic or metal) are 18.2 Gallons...
All front tanks (plastic or metal) are 19 gallons with the exception of
a 22 gallon plastic tank all the way to the bottom.
Still confused? I am. The only way to know for sure is to completely empty
the tank and re-fill.
My experience with Fill-ups are 1-3 gallons less that the capacity listed.
Old May 6, 2008 | 09:45 AM
phillips91's Avatar
phillips91
that is really strange though. on all of my other cars and trucks i can always get a gallon or two more than the listed tank size. i didnt run it till it died, just until it was on E for a good while. i may run it till it starts cutting out and then fill it up. ive got a 2000 super duty too and when the low fuel light comes on and its on E, i still have 8 gallons in the tank and can go another 120 miles easily.
Old May 6, 2008 | 01:30 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Originally Posted by Cuda_jim
The only way to know for sure is to completely empty the tank and re-fill.
I agree with Jim, so you never know, you should drive till out of fuel and refill
(Thanks Jim for try to rep, I also wanted to do but .... )
Old May 6, 2008 | 01:55 PM
Robbgt's Avatar
Robbgt
Well, I'm pretty sure my front tank is 22... I've had it down around E and it took 21 Gallons, unless there are pump gremlins!!!
I'd check for you guys, But the last time I filled completely or let it run down was when I was doing mileage testing, now it just hurts the wallet to much...
-Robb
Old May 6, 2008 | 03:14 PM
884x4broncoII's Avatar
884x4broncoII
it takes both my tanks 15 galons to fill from all the way in the red 13 gallons from when the needle hits the e, i guess my truck has a large reserve capacity...lol
Old May 6, 2008 | 03:48 PM
fishmanndotcom's Avatar
fishmanndotcom
*OFF TOPIC*
you need to be VERY careful when filling up. I have heard of several station in GA pulling this crap. they re-calibrate their pumps to show you have pumped more than you really have. i have seen it on some 20/20 news show somewhere and it was quite appalling! I copied and pasted this from an e-mail i received at work about this...
This is a true story, so read it carefully.
On April 24, 2008, I stopped at a Kangaroo BP gas station, located at 1325
Main Street , Cartersville , GA. My truck's gas gauge was on 1/4 of a tank.
I use the mid-grade, which was priced at $3.71 per gallon. When my tank is
at this point, it takes somewhere around 14 gallon's to fill it up. When the
pump showed 14 gallons had been pumped I began to slow it down, then to my
surprise it went to 15, then 16. I even looked under my truck to see if it
was being spilled. It was not. Then it showed 17 gallons had been pumped.
It stopped at almost 18 gallons.
This was very strange to me, since my truck has only an 18 gallon tank. I
went on my way a little confused, then on the evening news I heard a report
that 1 out of 4 gas stations had calibrated the ir pumps to show more gas had
been pumped than a person actually got.
Here is how to check a pump to see if you are getting the right amount:
Whichever grade you are using, put EXACTLY 10 GALLONS in your tank, then
look at the dollar amount, if the dollar amount is not EXACTLY 10 times
the price of the fuel you have chosen, then the pumps are rigged. In my
case as I said the mid-grade was $3.71 9/10 per gallon, my dollar amount for
10 gallons should have been $37.19. If I had only check the pump. It
doesn't matter where you pump gas, please check the 10 gallon price. If you
do find a station that is cheating, contact the Georgia Agriculture
Department, and direct your comments to Tommy Irvin, Commissioner. In other
states contact proper authorities.
Please don't delete this until you have sent it to all people in your
address book. We need to put a stop to this outrageous cheating of
customers. The gas companies are making enough profits at honest rates
*BACK ON TOPIC*
sorry guys, we gotta look out for each other, just trying to spread the word!
-cutts-
Old May 6, 2008 | 03:57 PM
Robbgt's Avatar
Robbgt
fishmanndotcom, Thanks you very much for posting that! Rep points sent! I'll have to keep an eye out... I guess I should ask, is it possible for the stock front tank in a 4x4 reg cab auto to have a 22 gal capacity? Jim I'm having trouble figuring that table out...
-Robb
Old May 6, 2008 | 05:09 PM
Cuda_jim's Avatar
Cuda_jim
Robb, Me too! I think they put in the tank(s) that were available for the day it was built.
If it's a 22 gallon tank it has to be plastic...according to the list above.
