ford mini starter
Old May 5, 2008 | 06:55 PM
pipman76's Avatar
pipman76
Thumbs up ford mini starter
i need to know is the newer 1992-97 mini starte a direct bolt on for the mid 70,s 460s or does the bendix need to be changed
Old May 6, 2008 | 06:28 AM
kjett's Avatar
kjett
Should be a bolt on and go, but you may need to shim it to keep it lined up with the flywheel.
Old May 6, 2008 | 01:17 PM
dutchlincoln79's Avatar
dutchlincoln79
Okay, i ask myself this too, as it seems that all 385 AND 335 series are equal...
But: when i search a little, i find 9 tooth, as well as 10 tooth starters...
What's up with that?
Makes me precousious on buying one...
Old May 6, 2008 | 07:40 PM
pipman76's Avatar
pipman76
i know the bolt holes bolt up the same but the bendix gear was what i thought might give a problem
