Aerostar Ford Aerostar
86 aerostar
Old May 5, 2008 | 04:53 PM
86pile's Avatar
86pile
86 aerostar
Hey, what's up? My 86 is being a pain once again. Hopefully someone knows what this part is. On the passengers side of the transmission pan, on the side there is a little round thing with a hose sticking out of it. The hose goes up to the engine somewhere. It's leaking out of that little hose down by the pan. I tried zip ties, that did not hold, I put a metal clamp on it, it still leaks. I'm afraid that the leak may be coming out of whatever that little brass looking round thing is. I'm not sure yet if it screws in or just pushes in, kinda hard to see it. But if anyone knows what that is or has had similar problems, please let me know, I'm over here getting stuck at red lights for a few seconds everytime I turn left. That is getting old quick. Thank you kindly.
Old May 5, 2008 | 05:29 PM
96_4wdr's Avatar
96_4wdr
transmission vacuum modulator
diaphragm shot and leaking ATF out of tranny. engine probably loaded up with sucked in ATF also
1986 FORD AEROSTAR Modulator
AutoZone.com | Repair Info | Transmission Modulator (Automatic) - How To Instructions
watch out for the small actuator pin inside. easily lost
clean out the engine with at least one can of Berrymans B12 or Seafoam thru the hole in the throttle body plate
see sticky Ford TSB thread at beginning on engine decarbon cleaning
Old May 5, 2008 | 06:57 PM
Aero-fan's Avatar
Aero-fan
Hey that's interesting that you're driving the first year for the aerostar. What type of engine does it have and what kind of mileage do you get with it? I was reading the '86 4 cylinder aerostars could get almost 30 mpg!
Old May 5, 2008 | 08:17 PM
93nighthawk's Avatar
93nighthawk
96 hit it on the head, that tube is not suppose to have liquid in it.
Replace your modulator (be sure not to loose the black pin that likes to come flying out when you remove it) and all will be good.
Old May 5, 2008 | 08:18 PM
86pile's Avatar
86pile
It has a V-6, but it still gets decent mileage. Like 25MPG. Maybe if I took the week and a half it takes to tune it up it would get 30MPG. Who knows.
Old May 5, 2008 | 08:22 PM
86pile's Avatar
86pile
Ok, that will make a good job for tomorrow night. Now two questions. One: How does it come out, and Two: where is this black pin gonna come out of that seems like I don't wanna lose it?
Old May 5, 2008 | 08:43 PM
96_4wdr's Avatar
96_4wdr
Old May 6, 2008 | 12:35 AM
Pablo-UA's Avatar
Pablo-UA
Is it early carburated Cologne V6 2.8 ore 2.9, like Taunus, Scorpio, Transit ore Sierra had in mid. 80-s?
Old May 6, 2008 | 03:52 PM
86pile's Avatar
86pile
Ok, I got this little thing out, I have the little black pin thing, so what do I have to do to test it or "rebuild" it? It doesn't look like it's gonna come apart too easily, But if I don't have to put any more money into this jalopy that would be great. It does have fluid all in it, I guess that's step one is getting that fluid out of there.
Old May 6, 2008 | 04:40 PM
xlt4wd90's Avatar
xlt4wd90
The vacuum modulator uses engine vacuum to control the position of that little pin. The vacuum works against a diaphragm in the body of that assembly. Most likely the diaphragm has cracked, disabling the modulator, and allowing fluid to be sucked into the engine. Normally, that assembly should not have any fluid in it at all. You can test it by applying some vacuum to it and see if it holds. You really can't fix something like that, so the only thing you can do is to replace it.
Old May 6, 2008 | 05:04 PM
copper_90680's Avatar
copper_90680
If you see fluid in the line, there are a few things you absolutely have to do:
1) Replace that modulator. It can't be fixed or rebuilt.
2) Replace the rubber tubing near the modulator and near the top of the engine. While you are at it, make sure the rest of the vacuum tubing on the manifold is in good condition. It's likely that they are ruined by the transmission fluid too.
3) Change the oil ASAP. You really don't want to drive around with transmission fluid in the crankcase.
Old May 6, 2008 | 07:12 PM
93nighthawk
3) Change the oil as ASAP. You really don't want to drive around with transmission fluid in the crankcase.
What he said!
Old May 6, 2008 | 09:32 PM
96_4wdr's Avatar
96_4wdr
FRAM Part # FM2336 {TRANSMISSION Transmission Modulator
Old May 6, 2008 | 09:48 PM
TheHandyman's Avatar
TheHandyman
Vacuum Modulator went bad on my Aero a few years ago and the Ford dealer had one for $9.00 ! It goes on easy and you van will run and drive better. When the diaphram breaks it sucks tranny fluid into the engine, so you have to keep adding fluid to the thing cuz it gets low a lot, the tranny wont shift as well, and it's a vacuum leak causing the engine to not run quite like it should.
Pay about $9.00 and fix all 4 problems at once. it's easy and cheap. A used one may be just as bad as yours. You can't fix the broken rubber diaphram inside.
Old May 7, 2008 | 05:50 AM
Pablo-UA's Avatar
Pablo-UA
Pile! post a snapshot please! I saw one 6-cyl '86 aero. All other are 4-cyl (lima ore cologne engines). It was carburated 2.8 cologne there
