Trouble Programming Fob
Old May 5, 2008 | 02:05 PM
Fraalan's Avatar
Fraalan
I have tried 4x leaving on off and run
I also tried 8x leaving on run and off.
I have programmed many fords with no issues.
Now my new 2003 isnt doing it.
The door locks don't engage, and no beeps.
Any ideas?
Old May 5, 2008 | 02:12 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Bad receiver box maybe? The box could have quit on you.
Also, are you 100% sure that fob is good? Good battery, & can be programmed to another truck?
Old May 5, 2008 | 02:36 PM
rbaker6336's Avatar
rbaker6336
** All transmitters must be programmed at the same time! Max of 4 transmitters can be programmed. **
- Keep the driver's door open.
- Electronically unlock the doors (Switch on door or working transmitter).
- Turn the ignition from OFF to RUN 8 times within 10 seconds, with the eighth turn ending in RUN. If the module has successfully entered program mode, it will lock and then unlock all doors.
- Within 20 seconds, press any button on an transmitter, and the doors will lock and then unlock to confirm that each transmitter has been programmed. Repeat this step for each transmitter.
** If the door locks do not respond for any transmitter, wait several seconds and press the button again. **
- To exit the programming mode:
-- Turn ignition to the OFF position.
-- Let the 20 seconds expire.
-- The maximum number of transmitters have been programmed
Old May 5, 2008 | 02:38 PM
Fraalan's Avatar
Fraalan
WELL I CANT EVEN GET INTO PROGRAMMING MODE AS THE DOOR LOCKS DONT POP.
i HAVE 2 FOBS AND NITHER WORK.
Old May 5, 2008 | 02:43 PM
rbaker6336's Avatar
rbaker6336
did you check fuses?
Old May 5, 2008 | 02:46 PM
Fraalan's Avatar
Fraalan
yeah after work I will check fuses and disconnect battery for a few minutes for a reset.
Old May 5, 2008 | 03:18 PM
jeff7825's Avatar
jeff7825
Are you sure that you even have keyless entry?
Old May 6, 2008 | 08:53 AM
Fraalan's Avatar
Fraalan
you know that is a good question. seeing that I dont have an overhead console i probably don't.
Odd that a XLT has the FX4 package but missing some of the basics.
Would a decent alarm solve this?
Old May 6, 2008 | 09:43 AM
jeff7825's Avatar
jeff7825
You could get an alarm with keyless. I don't really know anything about them or what one would cost. But then you would have an alarm on top of keyless entry, instead of just keyless. You could also get a remote start with it as well.
Old May 6, 2008 | 01:45 PM
Fraalan's Avatar
Fraalan
Yea $250 out the door. problem solved.
Next..
Old May 6, 2008 | 04:27 PM
BENG0924's Avatar
BENG0924
I have an 03 250 xlt fx4 with no RKE i bought the remotes tried to program didnt work called ford my truck has no RKE i then trashed my remotes
