Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Todays project
Old May 4, 2008 | 09:38 PM
Corner Gas's Avatar
Corner Gas
Todays project
was to put in the new gas tank on 78. Everything went smoothly and only took a couple of hours to do. Found something interesting in the old tank but not sure how it got there. Its a large cable with a plastic coating.
Old May 4, 2008 | 09:42 PM
danmansjimmy's Avatar
danmansjimmy
probably someone checking the fuel level at one time or another, maybe gauge was not workin or they wanted to syphon some out
Old May 4, 2008 | 09:44 PM
danmansjimmy
oh just noticed the pics that was a pretty big cable. also did you put any rubber strapping in between the straps, old tire tubes work good for that
Old May 4, 2008 | 09:50 PM
Corner Gas's Avatar
Corner Gas
Yup, used some carpeting I had left over from doing the cab.
Old May 4, 2008 | 09:52 PM
Fullcrew7.3's Avatar
Fullcrew7.3
Lookin good. That's quite the chunk of cable you found there??????? A new mystery to ponder....
Old May 4, 2008 | 10:07 PM
96sherm's Avatar
96sherm
looks good. i got a good side gas tank if anyone needs...
Old May 4, 2008 | 10:50 PM
preppypyro's Avatar
preppypyro
Good job, looks really nice.
Are you painting the frame at all?
Old May 4, 2008 | 10:54 PM
Dustin1690's Avatar
Dustin1690
Good job looks great
Old May 4, 2008 | 11:07 PM
Fomoko1's Avatar
Fomoko1
I`m afraid that the carpeting will retain moisture and rust out where it touches the tank, you`d be better off with rubber.
Old May 4, 2008 | 11:11 PM
Corner Gas's Avatar
Corner Gas
I am not sure yet, I was thinking about it.
Old May 4, 2008 | 11:21 PM
Snowking's Avatar
Snowking
Looks good.
I don't think I'd paint the frame. Usually if people see the frame the trucks most likely in a ditch upside down.
Old May 4, 2008 | 11:24 PM
preppypyro's Avatar
preppypyro
I personally think it would be a good idea. It always looks so nice when its all clean and painted.
Old May 4, 2008 | 11:26 PM
Snowking's Avatar
Snowking
It does, but really unless you are COMPLETLY restoring the truck I don't.
Old May 4, 2008 | 11:32 PM
preppypyro's Avatar
preppypyro
Yeah I guess that makes sence too. Kinda like painting half of the box haha.
Old May 4, 2008 | 11:38 PM
Corner Gas's Avatar
Corner Gas
I was going to do the parts you can see for sure like the rearend and stuff, and what ryan said makes good sense too, so that may be good enough for now.
Soonerz75
May 18, 2004 09:09 AM
PATS2002
Jan 2, 2003 09:06 AM
parr4
Apr 8, 2002 06:17 PM
jimarlie
Aug 2, 2001 01:00 PM
jowilker
Jan 23, 2000 03:28 PM
