6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
programmer
Old May 4, 2008 | 07:00 PM
hansen's Avatar
hansen
programmer
What is a good programmer for the new 6.4?I have a bully dog that I had for my 6.0 is that a good one?Will a programmer delete the dpf for better mpg?
Old May 4, 2008 | 07:04 PM
KingRanch250's Avatar
KingRanch250
This is a hot topic. Look through the post in this forum and you will find many conversations on DPF delete and programers that are being tested. Lots of info here>>> Good Luck
Old May 4, 2008 | 07:34 PM
SouthTexasDiesel's Avatar
SouthTexasDiesel
The big programmers for the 6.4 have been SCT, Spartan, and KEM. Currently SCT is the only one I know of that has released the DPF delete tune required to remove the DPF.
Removing the DPF will get result in better mileage, but it mostly depends on your driving habits and the terrain.
Old May 4, 2008 | 08:38 PM
hansen's Avatar
hansen
SouthTexasDiesel what is the difference in the street proformer and the extreme proformer on the sct livewire?Do they make one that has both like the bullydog?
Old May 5, 2008 | 12:53 AM
SouthTexasDiesel
The extreme just has the higher horsepower tune on it and it comes with the EGT probe. Other than that they're the same.
Old May 5, 2008 | 07:04 AM
hansen's Avatar
hansen
southtexasdiesel does a guy need the egt probe?What do you recommend?
Old May 5, 2008 | 01:17 PM
BASSHUNTER's Avatar
BASSHUNTER
I have the new BullyDog PMT on my 2008 F250 and it has been flawless.No probes because it uses the Factory EGT monitor system.Just wire it to power and plug it to the OBD port. Good Luck
Old May 5, 2008 | 02:32 PM
nordberg's Avatar
nordberg
according to sct you have the ability to monitor 1 of three egt sensors that are cuurently in the exhaust already. the sensor that is the closest to the manifold is called #1 (go figure) but supposedly it reads in celsious.
Old May 5, 2008 | 03:29 PM
hansen's Avatar
hansen
basshunter what kind of fuel mpg are you getting with your bullydog?What are the hp settings,also does that avoid the warrenty?
Old May 5, 2008 | 04:18 PM
69cj's Avatar
69cj
Any tuner detected by Ford or the other manufacturers will void your engine and probably trans. warranty.
Old May 5, 2008 | 05:05 PM
fordfish's Avatar
fordfish
read the imprint on the muffler/resinator....FMC has covered their azzes everywhere you look on the 2008
