Windshield Wiper Switch
Old May 4, 2008 | 09:20 AM
abnjumpmaster's Avatar
abnjumpmaster
On my 1979 F100 there is a one wire (Blk) coming off the actual switch (Wipers do have delay option). I assume this wire is a ground and secured it to one of the instrument panel securing screws. Is this correct?
Old May 4, 2008 | 11:18 AM
Behemoth's Avatar
Behemoth
Yup, it's a ground...but I'd ground it to the dash itself, instead of the instrument cluster. The instrument panel is plastic, meaning bad connectivity. The wire should be long enough to find a good metal ground in there somewhere.
Old May 4, 2008 | 11:24 AM
19704X4F250's Avatar
19704X4F250
Usually, it is screwed to the steering column bracket behind the cluster, along with other grounds. That's where I find mine.
