96 7.3l
Old May 3, 2008 | 07:40 PM
cmac75's Avatar
cmac75
96 7.3l
<HR style="COLOR: #d1d1e1" SIZE=1> <!-- / icon and title --><!-- message --><TABLE width="100%" border=0><TBODY><TR><TD vAlign=top>Looking to buy 96 F350 97k. Anyone know what mileage to expect and what to look for in the deisel. Never had one.
Thanks
Chuck
</TD></TR></TBODY></TABLE>
Old May 3, 2008 | 10:06 PM
Neal 97 250's Avatar
Neal 97 250
What do you mean looking to buy?
'96 with 97k is low mileage. If you are looking at that it sounds good. How much maintenance record? etc. We need details
Old May 4, 2008 | 05:07 AM
Cuda_jim's Avatar
Cuda_jim
I stole this from tenn01psd350, kudos to hime for putting this together:
BTW: That's very low milage for a 96. Be sure it's correct...or find out why it wasn't used very much. You could run a Carfax report.
1. Visual: Body and rust are obvious items, nonspecific.
A. Engine
1) Check for any obvious fluid leaks, especially the engine valley, tranny weep hole area, and around the turbo and pedestal.
2) Check coolant with strips and find out the record of any changes or water pump replacement based on mileage.
3) If possible, do compression check, and Cylinder contribution test.
4) Inspect turbo inlet side vanes, should be straight and not dusted or jagged. Try to move the shaft in and out and up and down. Any real noticeable movement by hand is bad. Open and inspect air cleaner assembly for an idea of how it was maintained.
5) If possible, have fuel pressure tested at engine to check pump.
6) Check all intake /intercooler boots for residue or leaks and correct before trying to determine engine condition.
7) Look at oil pan for notorious rusting, make sure not beyond repaint type repair.
B. Transmission, driveline and 4x4 system.
1) Look for any obvious leaks.
2) With the system in 2wd, grasp and rotate both front drive axles and ensure they rotate freely. Go to the hubs, should rotate from lock/auto to free with no problems.
3) Grab rear driveshaft and push up and down along it's length checking for worn u-joints or bearings.
4) Check front and rear differential levels. (An indicator of maintenance) Level should be at or w/in 1/2 inch of check plug.
2. Test drive. If you have never owned a 7.3 PSD, try to get a 7.3 owner to test drive it. I did this with a friend who bought his new. Invaluable evalation because you have no idea. A stock PSD may feel like a slug to the gasser uninitiated but it can pull a house off of it's foundation. So here we go.
A. Drive more than one PSD truck that you are considering. Whether Auto or Stick, it will give you an idea of the overall condition of the one you want to buy. Cost = 0. Learning curve = super high. Dealers have a ready supply.
B. Startup. Turn key and watch wait to start light. The colder it is the longer it will take but should take no longer than 15-20 seconds on even cold days. Start engine. Should crank readily and turn the tach while cranking. Should start within 2-5 seconds of cranking. The colder it is the longer it will take but if longer than 5 seconds there may be a problem. Even in colder weather. If it does not not start easily on the second try, suspect problems, possibly in the glow plugs or GP relays. If it does not crank readily, or seems to drag, suspect batteries first, starter next, then cables.
C. Driving. Check all operational items. Don't be rushed. This is a major investment and you want to get it right. Even small items like the cruise will set you back.
1) Auto tranny: will feel like it takes the throttle to get moving with a stocker. The higher the mileage, the worse this will be. The shift should be smooth but slippy with a stocker. Long to engage. Convertor lockup will be almost imperceptible, but there. Will lock up at about 45 to 60mph depending on throttle in OD. Should drop out of OD with input to brake or reduction of speed.
2) Manual trans:
3) Ride: if it is bouncing down the road, you can look to having some problems to take care of. These can be tire balance. Tires, or some unexplained seemingly incurable symptom that you may have to live with which is unacceptable and not common, but does happen. Some say it is an out of balance driveline but there is no universal cure.
4) Exhaust drone. Only happens with aftermarket exhaust due to what I believe is harmonics resonating in the thinner walled aftermarket systems. Not a big solution at present but not a performance issue.
5) Performance. There is no hesitation in the PSD 7.3 when all is in working order. Any hesitation is an indicator of a problem. By design, if all is in order, at throttle tip in, it simply responds. No excuse such as mileage considerations. This = repair bill.
Old May 4, 2008 | 08:11 AM
cmac75's Avatar
cmac75
Its an Oklahoma truck no rust, maint records don't have any. Carfax shows mileage is correct. Drives good I drove 2 2000 with PSD 1 with232k and 1 with 80K This one pulls harder than the 232k but not nearly like the 80k. I don't know if it had a chip done but it seems like it did. There asking 10500 so price sounds okay with that mileage?
Thanks
Chuck
