stalls when put in gear
Old May 3, 2008 | 01:25 PM
Ds7776's Avatar
Ds7776
I have a 1970 F100 with a 390 2 barrel it has an aftermarket holley automatic choke on it when its cold I have to be easy on the throttle or it will kill or back fire through the carb ive replaced the accelerator pump. The bigger prob is occasionally especially when im in a hurry to get to the fire dept. it will start fine but when I put it in gear it dies it will do this 3 or more times before I can take off and have to be real easy on it.
Old May 3, 2008 | 01:40 PM
Bear 45/70's Avatar
Bear 45/70
You need to adjust your choke. Both the butterfly of the choke valve and high idle adjustments.
