6.0 prob
Old May 3, 2008 | 12:42 PM
augief350's Avatar
augief350
6.0 prob
I have a 2003 F350 with a 6.0 I bought used it has 189,000 miles it has a cold power prob if I dont let it run for 10 min or so it has a major lack of power I can put it to the floor and she just dont go . there is like a lack of responce all I can say is traffic has to very clear befor I pull out. but if it warm she will lay a posi patch a block long. any thoughts? thanks augie f350
Old May 3, 2008 | 01:40 PM
bismic's Avatar
bismic
Could be a number of things. How mechanical are you? the first things (in order) I would try:
1. Pull and clean your egr valve - while you are at it, clean the intake manifold, EBP tube, MAP sensor hose.
2. pull and clean turbo if #1 doesn't help.
Keep us informed.
Old May 3, 2008 | 01:43 PM
critter68's Avatar
critter68
now if it's only in cold weather it could be your fuel gelling. you can buy fuel treatment at walmart or truckstops etc...
Old May 3, 2008 | 02:23 PM
augief350's Avatar
augief350
thanks
Yes I am mechanicaly inclied and I will check those items as far as the geling of the fuel it happens in 80 degree weather was born on a farm so know about fuels Im thinking it is the egr vale because the turbo spools up it just wont roll out untill its warmed up then I have to be good or it looks for traction and will run like a scared rabbit
Old May 3, 2008 | 08:26 PM
bismic's Avatar
bismic
I just read that a diesel tech on another forum diagnosed your exact symptoms as injector problems. Have you checked for DTC's?
Old May 3, 2008 | 10:47 PM
whalerron's Avatar
whalerron
Does your truck have the "detune when cold" flash? Recall 05B35 was issued in 2006 and it detunes the engine until the engine comes up to operating temperature.
Old May 4, 2008 | 09:10 AM
69cj's Avatar
69cj
Might also see if you have the latest induction heating flash for sluggish cold injectors commonly called stiction. This has solved many cold start / run issues here.
