Old May 6, 2001 | 10:56 PM
qwerty's Avatar
qwerty
i have a 69 302. i put in a new timing chain, new carb, distributor, and coil when i put it together. when i try to start it all i get is flames out of the carb. sometimes it turns over slow while backfiring and when i open the trottle wide open it turns over faster. with the mark on the balancer at top dead center, i checked the #1 piston: at the top, and the #1 cylinder valves: both closed. then i checked to make sure my rotor was pointing at #1 and not #6. i have checked myplug wires over and over. the screws on the factory 2 bbl carb are now set at 1 1/2 turns because i thought i might have been flooding. i don't have restricted exhaust because i have open manifolds right now. any help is GREATLY appreciated.
Old May 7, 2001 | 11:19 AM
loudfords's Avatar
loudfords
Try putting a timing light on it while turning it over. It may be too far advanced.
1979 F150 Custom: nothing under the hood at all (again)
1987 F150 XLT Lariat: 88 351W EFI
75 351W: soon to have 91 heads, ?? cam, double roller timing chain, Edelbrock Performer intake & Holley carb and be put back in 79 F150
84 351W: waiting for ???
Chevy 454: waiting for a truck (Mazda?Nissan?)
Old Jun 7, 2001 | 04:50 PM
pitstop2k's Avatar
pitstop2k
I had a similar problem when I tried firing my 351 windsor over (I used a cam with the 302 firing order) I thought that everything was right but it turns out I was 180 off on the timing. I ended up pulling the no. 1 plug and watching to make sure that the no. 1 cylinder was coming up on it's compression stroke. All the timing marks were lined up right and the valves were sitting where they were supposed to be. I would also check your timing. Hope this helps.
Old Jun 7, 2001 | 08:28 PM
91Bronco's Avatar
91Bronco
moonshine34
Jun 9, 2013 09:23 AM
Taz79
Feb 11, 2007 10:12 PM
Hellbore
May 24, 2006 10:31 PM
orangedbowl
Jan 18, 2005 01:59 PM
LedheadELH
Jan 8, 2005 10:48 AM
