codes 32 & 67
Old May 3, 2008 | 05:05 AM
hotrod351's Avatar
hotrod351
codes 32 & 67
ok im getting the codes 32 and 67. my truck is a 90 f150 with the 4.9. starts but idles rough and will die until warmed up for a while. the code book says 32 is egr pressure feedback but for 85-89, not 90. it says 67 is ac compressor clutch switch fault, i don't know how the ac clutch switch would make it start and run rough when its not on. i love the truck but lately it seems its everything going. im going to try to check the egr valve out but will more than likely buy one and hope that takes care of the rough start up idle. i know a egr valve not working right will cause rough idle on a carb engine. any help with figuring this out would be appreciated.
Old May 3, 2008 | 07:26 AM
oachs83's Avatar
oachs83
This should help
Old May 3, 2008 | 11:29 AM
hotrod351's Avatar
hotrod351
in your answer there are two boxes that say have been moved or deleted.
Old May 3, 2008 | 02:12 PM
oachs83's Avatar
oachs83
Someone must have deleted them, I'm in a jam right now and gotta go but I will post them up. Basically it is the process on checking the EGR for what wrong. It basically tells you to replace it though. Your A/C is a seperate issue and diagnoses that as well.
