Level kit differences
Old May 7, 2008 | 09:50 PM
  #31
MBBFord's Avatar
MBBFord
The rear is 2.5" higher than the front stock.
So add 1.5" and that's 4" higher.
Put a 2" up front and that still makes the rear 2" higher.
IF you put the 2.5" in the front, with 1.5" in the back, that would make the rear 1.5" higher in the rear.
Old May 9, 2008 | 12:04 AM
  #32
SDTruckMan's Avatar
SDTruckMan
One the AS store front it says the AAL is 1-1/2 to 2 inch raise.???
Old May 9, 2008 | 08:28 AM
  #33
MBBFord's Avatar
MBBFord
From the guys on here that used it, they said it gave 1.5" lift......FYI
Old May 9, 2008 | 10:21 AM
  #34
delta767's Avatar
delta767
if anyone bought the F430 3 inch leveling kit from skyjacker if you break the strut like i did skyjacker doesnt make that kit anymore so your SOL to get parts for it im going round n round with skyjacker the kit only has 7000 miles on it and 1 yr 4 months old and the strut just broke clean fyi your screwed if the strut breaks will have pics when i pick up truck later on today
Old May 18, 2008 | 01:30 PM
  #35
SDTruckMan's Avatar
SDTruckMan
Another question on these..
Does the AS kit (since its metal on metal) once installed make any noises (squeaks/thuds/etc) in the front end when the truck is driven over pot holes, railroad tracks, road to driveway approachments, things like that.
Vs if you went with the daystar kit which has the poly in it.
Old May 18, 2008 | 03:19 PM
  #36
NASSTY's Avatar
NASSTY
No, because the factory setup is already metal to metal where the strut mounts to the upper control arm.
Old May 18, 2008 | 06:07 PM
  #37
SDTruckMan's Avatar
SDTruckMan
Cool..
Gonna order the AS then.
Just hope im not gonna be draggin **** when I hook up the trailer
tbeaton99
1997 - 2003 F150
Aug 1, 2011 08:25 AM
rcklnhunter
6.7L Power Stroke Diesel
Aug 27, 2010 01:46 PM
uscghutch
Mar 17, 2009 06:59 PM
skytow
Dec 3, 2005 07:46 PM
telemark8150
2004 - 2008 F150
22
Dec 2, 2004 04:45 PM
