fuel injection
Old May 1, 2001 | 11:25 PM
mike460's Avatar
mike460
fuel injection
Old May 27, 2001 | 11:49 PM
orangeford's Avatar
orangeford
fuel injection
Are there any fuel injection kits for the 351w?
Old May 28, 2001 | 11:21 AM
loudfords's Avatar
loudfords
fuel injection
I think Summit Racing has them. You can order a free catalogue off their website.
1979 F150 Custom: nothing under the hood at all (again)
1987 F150 XLT Lariat: 88 351W EFI
75 351W: soon to have 91 heads, ?? cam, double roller timing chain, Edelbrock Performer intake & Holley carb and be put back in 79 F150
84 351W: waiting for ???
Chevy 454: waiting for a truck (Mazda?Nissan?)
Old May 28, 2001 | 11:01 PM
mike460's Avatar
mike460
fuel injection
well, you could use a production lightning lower and upper intake(this would be best for performance) and painless wiring makes a complete harness for the fuel injectors, all the sensors, etc.. and you could use just about any computer you wanted, but i would suggest if you were to go with the painless kit to use a mustang computer. good luck and i hope this helps. oh, and if you dont wanna go with that style, holley makes a fuel injection setup that is a 4 barrel throttle body injection type. that way you can use a 4 barrel intake like an edelbrock, weiand, anything that a carb would fit on. barry grant makes one like this too, but it is hella expensive. good luck,
mike
Old May 29, 2001 | 06:43 PM
rc351w's Avatar
rc351w
fuel injection
Orangeford:
If your considering switching a carbed motor to EFI, Holley makes a 'Four Barrel' TB injection system that installs on a four barrel intake inplace of a carb. I have no idea how much but you can look it over on their website. They also make MPI systems I believe.
RCC
Old Jul 5, 2001 | 10:31 PM
jruppert's Avatar
jruppert
fuel injection
Your best bet would be to either find a truck '88 or new with a 351W and take all the wiring harness sensors and computer out. Or if you really want to go with it find a '89 or new Mustang and get the computer, harnesses, and sensors to do the swap. Make sure if you go from the Mustang that its a Mass Air Flow setup. That will allow you to change cams and get better response from the computer. The Mass Air setup is much more efficient especially if you want to do a Lightning swap. You might was well add on a Edelbrock Performer Package rather then the Lightning. I think its better. Good Luck
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
