Rear window
Old May 5, 2008 | 04:06 AM
hoxiii's Avatar
hoxiii
The 73-82 aluminum sliders also use the same gasket as the fixed rear glass. The 83+ glass got the double width channel.
Justin
Old Feb 6, 2009 | 09:59 AM
wilmac150's Avatar
wilmac150
F4TZ15422B30B .. Sliding Rear Window Kit
MSRP: $307.72 / ftepartsguy.com price: $221.56
OUCH!!!
anyone have a used weatherstrip?? I have the window already.
Old Feb 6, 2009 | 10:30 AM
mds47588's Avatar
mds47588
Do ya want a weatherstrip with or without the plastic chrome channel?
I can get ya one today.
Old Feb 6, 2009 | 01:26 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Correction:
1973-1981 (some 1982 possibly due to dealer kits) have the aluminum sliders, with brushed aluminum frame. Seal (slider only for 1980-1981, slider and fixed glass for 1973-1979): D3TZ-1042084-A
1982+ has the black frame, double width channel. Seal/ slider only: D2TZ-1042084-A
1980-1996/1997 rear window seal without insert/ fixed glass only: E0TZ-1042084-A
1980-1996/1997 rear window seal with inserts / fixed glass only: E0TZ-1042084-B
The rear window of the 1973-1979 has thicker glass than the 1980-1996/1997 counterparts so they have different seals to match the glass thickness. as example:
1973-1979 rear window/ without insert / fixed glass or slider / D3TZ-1042084-A
1973-1976 with wide chrome inserts / Fixed Glass only / D3TZ-1042084-C
1977-1979 with narrow inserts / fixed glass only / D7TZ-1042084-A
What makes it more confusing is Ford discontinued all the seals and glass for the rear windows for the 1973-1979 and used the 1980-1996/1997 rear window glass as service part replacements.
So if you ever changed the rear window or seal out of your truck and found the rear seal doesn't fit exactly right, this is why.
Old Feb 6, 2009 | 06:08 PM
Fordzilla80's Avatar
Fordzilla80
I hate my Aluminum slider.Stupid thing's falling apart.The windows are easy to open,but a pain to close,and when the window is locked,you can still move both the panels of glass to either side of the cab,and it gets you about a 6 inch gap.So whenever I close the window,I have to put small shoe moulding size boards on either side of the window so you can't move the panes to either side.I'm looking to get a tinted sliding rear window out of a 94-96.
I have a question while were on the topic of these windows.Is the window glass on my rear window the same size as that of a 94-96?I'm inclined to believe the pieces are smaller on my truck because of the aluminum frame.But i'm not sure.
Old Feb 6, 2009 | 06:20 PM
81-F-150-Explorer
It's not the same.
However a 1982-1996/1997 slider window will work a treat. Just need a new seal with the new window. E2TZ-1042084-A
You can also rebuild your old window, (preferable if going for true restoration) but the seals are hard to come by. There was a thread in the 1973-1979 section, on replacing all the window seals in the 1973-1981 slider window. All the seals are obsolete, but can still be gotten through the parts locator system when the original thread was typed. Numberdummy may have more info on that if you are looking to rebuild the old one.
P.S. your seals are worn out, why the window won't work right.
Old Feb 6, 2009 | 06:33 PM
Fordzilla80
Originally Posted by 81-F-150-Explorer
It's not the same.
I have came to HATE the aluminum slider,so rebuilding it won't happen.I feel it won't be worth my time.Plus,I want to carry a gun rack in my truck,and I don't want whoever's followin me or administrators at school to be able to see my rifles.
I kinda figured that's what it was.They're pretty dry rotted.Thanks for the help man!
86f150step
Oct 28, 2013 05:24 PM
86 ford truck lover
35
Jun 2, 2012 07:52 AM
dieselbronc
1978 - 1996 Big Bronco
May 16, 2012 07:12 PM
98screamer
Oct 15, 2001 11:08 PM
