Sorry, another code question
Old Apr 30, 2008 | 12:03 PM
just another truck's Avatar
just another truck
Okay, the following are codes i picked up today
P1249= waste gate not detected
0743= no clue
P0475=no clue
p1211= and again, no clue
Any thoughts?? I know I could probaby find them on this forum and I am sorry for not searching, but lunch is about to end.
Old Apr 30, 2008 | 12:15 PM
brnab1's Avatar
brnab1
Thumbs up
Here try this this should help https://www.ford-trucks.com/article/idx/7/248/article/Ford_OBDII_Diagnostic_Trouble_Codes__Powerstroke_D iesel_Codes.html
Old Apr 30, 2008 | 12:25 PM
just another truck
Originally Posted by brnab1
Thanks For the quick response, the link isnt working
rbaker6336's Avatar
rbaker6336
P0743 TCC Torque converter clutch system electrica lFaulty solenoid, circuit, PCM
only one to worry about I think
P0475 EPR Exhaust pressure control valve malfunction Open/grounded ckt., solenoid
open/shorted, failed PCM
P1211 IPR ICP pressure above/below desired IPR valve failed, stuck, or shorted to ground
Old Apr 30, 2008 | 12:29 PM
just another truck
po743 could be set by the tc lock up switch???
0475, this would be the at the pedistal, used for heating the truck quicker ? disconnected
p1211, need to look this one up as to the cause
Thank you!!!!
Old Apr 30, 2008 | 12:32 PM
rbaker6336's Avatar
rbaker6336
you got two right if you have a chip or tuner you can get the 1211
Old Apr 30, 2008 | 12:35 PM
just another truck
Its a great day, I have the hypertech 3
thanks Ray.
as far as the wastegate, I disconnected that last week to see if I noticed anything, I didnt, so I shall be reconnecting.. Thanks alot!!!
Old Apr 30, 2008 | 12:40 PM
PaysonPSD's Avatar
PaysonPSD
0743= no clue
P0475=no clue
Code- Circuit Index - Condition Description - Probable Causes
P0475 - EPR - Exhaust pressure control valve malfunction - Open/grounded ckt., solenoid open/shorted, failed PCM
P0743 - TCC - Torque converter clutch system electrical - Faulty solenoid, circuit, PCM
P1211 - IPR - ICP pressure above/below desired - IPR valve failed, stuck, or shorted to ground
P1249 - WG - Waste gate steady state failure - GND short, plugged hose/port, solenoid, actuator
Old Apr 30, 2008 | 12:50 PM
just another truck
Thanks Robin,
Old Apr 30, 2008 | 01:14 PM
PaysonPSD's Avatar
PaysonPSD
Thanks Robin,
No problem, just wish I were quicker.
