Bypass hose
Old Aug 15, 2001 | 11:19 AM
loudfords's Avatar
loudfords
Bypass hose
Ok, got engine bolted into truck finally (don't you hate it when your job interferes with your truck) and I'm connecting all the stuff to the engine again. Which port on the water pump does the thermostat bypass hose connect to? I think it goes to the lower-passenger side port right? Engine is 351W with v-belt accessories & water pump.
Thanks, Chad.
1979 F150 Custom: nothing under the hood at all (again)
1987 F150 XLT Lariat: 88 351W EFI
84 351W: soon to have 91 heads, Crane PowerMax cam, double roller timing chain, Edelbrock Performer intake & Holley carb and be put back in 79 F150
86 & 87 Bronco II: next winter's beater
Old Aug 15, 2001 | 12:25 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Bypass hose
I just looked under the hood of my truck.
Yes, you are correct. The lower nipple is for the bypass hose and the upper one is for the heater.
Old Aug 16, 2001 | 07:37 AM
loudfords's Avatar
loudfords
Bypass hose
Thank you !!! :-)
Old Aug 18, 2001 | 11:39 PM
ecarter50's Avatar
ecarter50
Bypass hose
Dick Kranz
Dec 20, 2016 01:48 PM
azgunner
Jun 15, 2016 03:06 PM
Torquin
Feb 12, 2016 05:42 PM
annaleigh
Jan 14, 2016 09:22 PM
64fordf100292
Nov 2, 2007 07:45 PM
