1964 block, solid or hyd. lifters???
Old Apr 29, 2008 | 11:15 PM
crescentwrencher's Avatar
crescentwrencher
would i have solid or hydraulic lifters in my 1964 fe?
which is better? in your opinion. pros vs. cons
Old Apr 29, 2008 | 11:54 PM
Bear 45/70's Avatar
Bear 45/70
Depends on which engine you have. Most had hydraulic but a number of the high performance motors had mechanical.
Old Apr 30, 2008 | 12:12 AM
85e150's Avatar
85e150
By '64 only 427s had solids.
Hydraulics are better. Even if you are going to rev it to 6500, you can use hydraulics. (because if you were going to rev it to that, you'd be rebuilding the engine with lots of shiney new parts....)
No adjustment required once it's set up correctly.
Old Apr 30, 2008 | 12:37 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1964/65 Galaxie Police Cruisers; 1966/69 Fairlane/Torino/Montego; 1967/69 Mustang/Cougar HiPo's have adjustable rocker arms (B8A-6564-B) and solid lifters (C4AZ-6500-B).
428
1966 Galaxie Police Cruisers have solid lifters and adjustable rocker arms. Same part numbers as above.
Old Apr 30, 2008 | 09:07 AM
crescentwrencher
well mine is an ex 390 that appears to be converted to a 410, so my guess is hydraulic.
Old Apr 30, 2008 | 01:33 PM
Freightrain's Avatar
Freightrain
I just like the "tic-tic" of solids. Everything I got has solids in it.
Old Apr 30, 2008 | 06:54 PM
crescentwrencher
well my engine does tick, and somone swapped a 428 crank im there, maybe sombody converted it,
is there any way to tell without major dissassembly?
Old Apr 30, 2008 | 06:59 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
If you have non adjustable rockers it's a hyd lifter engine.
Old Apr 30, 2008 | 08:48 PM
crescentwrencher
ok, it official, ive got hyd lifters, i pulled the valve cover
