Up Pipe Removal
Old Apr 29, 2008 | 09:38 PM
mind's Avatar
mind
Up Pipe Removal
Hey guys need to ask a question because i have my trans pulled right now and need the truck back asap. Anyways i have a 01 F350 7.3 getting the front seal replaced, and looks like the rear main now since i seen a little leak from there too. Saw some nice soot coming down from my up pipes and while its nice and easy to get to them now i wanna replace the gaskets. Cant do the bellowed ones no time/money but would like to some day. Anyways can i pull those out without taking off the manifolds or turbo? Thanks all.
Old Apr 29, 2008 | 09:43 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Yes, you can pull the pipes without removing the manifolds. You may need to loosen the clamp that connects the cast iron connector to the turbine inlet of the turbo, and remove the collector and the pipes as a whole. when reinstalling, loosely hang the pipes in the manifold, install the bolts, snug them down but leave a 1/4 turn loose or so, connect the collector to the turbine, then tighten the donut connection. Finally retighten the lower two at the manifold. Also, make sure the oil leak that is looking like its coming from the rear main isn't up in the valley. There's a drain hole that lets stuff fall down into the tranny bellhousing, mostly looking like a rear main leak even though i've NEVER heard of one....
Old Apr 29, 2008 | 09:45 PM
bdrummonds's Avatar
bdrummonds
Since you have the tranny out you should be able to reach up and undo the bolts that hold the flanges onto the collector. Then with the pipes un mounted from the manifolds you should be able to remove each one, and replace the donuts.
PS a rear main seal going bad is highly unlikely, look around your turbo pedistal, or your EBPV actuator for your leak.
Yeah basically what Kris said.
Old Apr 29, 2008 | 10:19 PM
schlepprock250's Avatar
schlepprock250
Giving the job it is to replace the uppipes (or donuts) (PITA!!) Sure would be nice if you could find the money for the bellowed uppipes, man doin the job with the tranny out would be VERY nice. I replaced mine last weekend and to be honest...its not a job I want to do again. But I sure know how it is to not have the liquid cash to do something spur of the moment....good luck...
Schlepprock
Old Apr 29, 2008 | 10:44 PM
big poppa's Avatar
big poppa
Man, i worry about the day i see soot from my up pipes, ohhh noooo.(not exact words but close.)
Old Apr 29, 2008 | 10:52 PM
Cracker 73's Avatar
Cracker 73
While your under there check your manifolds for leaks . They could be leaking on a high mile truck.
Old Apr 30, 2008 | 08:05 AM
mind's Avatar
mind
Wow thank you very much guys.
Old Apr 30, 2008 | 07:23 PM
mind's Avatar
mind
Well i managed to break one bolt, and still need to take off 2 more on the upper flanges but there being a pain. Soaked them with pb blaster for the night though, cant i just reach up and disconnect the collector from the turbo?
Old Apr 30, 2008 | 09:00 PM
mike9999's Avatar
mike9999
Definitely, its similar to the downpipe connection.
Old Apr 30, 2008 | 09:25 PM
dustan52's Avatar
dustan52
This drain hole you speak of, does it need to be left alone or is there a mod to redirect the fluid. Does the ccv going into the intake make it look like a seal leak?
