Sponsored by: Real Truck
Help with decision on brakes?
Old Apr 29, 2008 | 04:47 PM
tracyclifton's Avatar
tracyclifton
This isn't about my SuperDuty, but I thought I would get the best opinions I know of. I have a 2004 Ford Freestar. Took it in to rotate the tires. Shop said the left rear caliper had been stuck at some point and rotor was trashed and inside pad was nearly to metal. Caliper isn't sticking now. The other side is great, rotor is smooth, pads are 50%. They said "you have to replace both rotors, both calipers, and of course pads. I've had Ford calipers go bad before and only replaced one with no problem. My decision is replace bad caliper, that rotor, turn rotor on other side and new pads. About $250 savings. Van only has 51,000 miles. Your thoughts please.
