I'm trying to figure out the gear ratio on my 06 350 SRW. I tried the manner described in the tech folder, but there were no numbers or letters vaguely close to what was there. Can't find any tags on the rear axle either. Any help?
The codes in the tech folder are not correct for the later model trucks. Well, at least some of them are not included. Check the body label on the drivers door frame for the axle code. Someone here can tell you what it is. For example, mine is 3L and is 3:73 limited slip. Chances are fair that yours is also 3L.
