how do i disable automatic headlights?
Old Apr 28, 2008 | 07:53 PM
sticks25's Avatar
sticks25
i have a 9/97 psd that i would like to turn the automatic headlight option off. whenever the truck is running, they are and there is several situations where i wish they wernt. how do i do it and is it possible?
thanks
andy
Old Apr 28, 2008 | 08:32 PM
Hussler's Avatar
Hussler
thanks
andy
On my 97 I just push the headlight switch in
Old Apr 28, 2008 | 08:35 PM
tjbeggs's Avatar
tjbeggs
Yes I am sure its possible as long as your not in Canada (DTRL are the law there). I know the module for the DTRL is mounted here (Red circle in lower right hand corner is for the day time running light module)
Should just be able to unplug it but I can't say for sure that the Headlights will work that way. SHould as the trucks with not DTRL just have a plastic plug in there.
Old Apr 28, 2008 | 09:24 PM
sticks25's Avatar
sticks25
driving lights
ill give it a shot.
thanks
Old Apr 28, 2008 | 11:02 PM
Vinford's Avatar
Vinford
My problem is trying to get mine to work.
I have to get it inspected and everything has to work including the day time driving lights.
TJ can you get to that plug without taking the front clip off (like your picture)?
Old Apr 28, 2008 | 11:11 PM
immastrokinnow's Avatar
immastrokinnow
i didnt know our trucks had day time running lights
Old Apr 29, 2008 | 04:56 AM
Cuda_jim's Avatar
Cuda_jim
You can turn them off with the parking brake. They are deactivated by the switch that activates the P-brake warning light in the dash.
Caution: Don't press the lever all the way down if you don't normally use your P-brake you can have them jamb up. A couple clicks should do it.
Old Apr 29, 2008 | 07:44 AM
tjbeggs's Avatar
tjbeggs
You might be able to get to it by removing the grill. If not you will probably have to remove the headlight bucket and parking light. 2 screws up top and two nuts at the back fo the core support.
Old Apr 29, 2008 | 09:39 AM
FARM69's Avatar
FARM69
I've always wondered what the pigtail was for. Good information TJ.
Old Apr 29, 2008 | 10:16 AM
Neal 97 250's Avatar
Neal 97 250
The Canada versions have it. They also have different speedo's for km/h
Old Apr 29, 2008 | 11:40 AM
immastrokinnow
gotcha. thanks for the info
Old Apr 29, 2008 | 11:51 AM
secondarychaos's Avatar
secondarychaos
I dont get this... my dad's chebby has them too, and he always wants them off.
What's the problem with DTRLs?
Old Apr 29, 2008 | 12:03 PM
immastrokinnow
i dont like them because when your trying to get in and out of somewhere late at night you dont want your headlights in your buddies house waking family members and such up. also they burn out light bulbs quicker. they can give a ticket for one being out even though you legally dont need them. just my .02
Old Apr 29, 2008 | 12:04 PM
tjbeggs's Avatar
tjbeggs
On the chevy's they always burn out! 90% of the chevy's I see driving around only have 1 DTRL lit!
Old Apr 29, 2008 | 12:06 PM
tjbeggs's Avatar
tjbeggs
The other thing about DRTL that I don't like is most people drive around with them in the evening and when it gets darker they have some light in front of them and they wait to turn on their lights. what they forget is that their tail lights aren't lit either!
