timing and engine noise
Old Oct 6, 2001 | 10:13 PM
bigdad4u2hug's Avatar
bigdad4u2hug
hello ,hey i have a question, i just tuned up my 1988 bronco,new wires,plugs ,cap, rotor, all filters , new tps sensor,new air by pass sensor ,,,,when i checked the timing it was a 7degrees,so i set it back to factory timing which is 10 degrees, now since i set back to factory i have this slight engine noise at bottom end ,,,, my questionis? before i reset the timing i never had this noise ,should i back off of the timing slightly/ any help will be apreciated
Old Oct 7, 2001 | 09:19 PM
DeGideo's Avatar
DeGideo
