A couple Questions
Old Apr 28, 2008 | 06:04 PM
jg09's Avatar
jg09
A couple Questions
I have a 1991 Explorer, and I was wondering what lever operated transfer case did these come with? Also how hard would it be to replace the OHV 4.0 with a SOHC 4.0, or a 302 or 351? Or this would be a really cool option a supercharged lightning engine. Thanks.
Old Apr 28, 2008 | 07:58 PM
Bear River's Avatar
Bear River
Former ******
Engine swaps on fuel injected vehicles is a little trickier than on carbed vehicles. You basically need the computer out of the donor vehicle, or at least a computer that can handle the motor you intend to use. Its not that difficult, but you should familiarize yourself with the process. You can also get programmable FI systems, such as Megasquirt and SDS.
Old Apr 28, 2008 | 10:17 PM
mrshorty's Avatar
mrshorty
BW 13-54 (manual shift version of the t-case you already have
Old Apr 29, 2008 | 02:34 PM
jg09's Avatar
jg09
Oh, okay. That's what I figured. Thought I'd ask, just in case. Can I replace the outer case with a manual shifted 13-54 and use my internal gears?
Also, if I get programmable fuel injection controller, will that only attach to the engine's wiring harness? Will the Explorer's stock ECU throw trouble codes at me?
Old Apr 29, 2008 | 05:19 PM
mrshorty's Avatar
mrshorty
As far as I know, the internals are the same, so I don't see why it wouldn't work, but I don't see any advantage to doing it, either (unless the manual shift tcase is broken inside).
I don't know what kind of programmable fuel injection controller you are referring to. Remember that the stock PCM's primary purpose -- its "raison d'etre" -- is fuel injection control. Anything that tries to replace/reprogram the PCM has to integrate itself properly into the engine management system. I'm sure that, if it's not done right, it will throw a CEL.
Old Apr 30, 2008 | 12:04 AM
Bear River's Avatar
Bear River
Former ******
If you use a custom FI controller, you remove or disable the factory FI controller. Note that before even considering a FI controller, you should check with your local emission and registration laws, many FI controllers are not street legal.
Using the computer from the donor vehicle is the best option, also OBD-II Ford computers can be reprogrammed to do almost anything you want.
Old Apr 30, 2008 | 01:59 PM
jg09's Avatar
jg09
Originally Posted by mrshorty
As far as I know, the internals are the same, so I don't see why it wouldn't work, but I don't see any advantage to doing it, either (unless the manual shift tcase is broken inside). I don't know what kind of programmable fuel injection controller you are referring to. Remember that the stock PCM's primary purpose -- its "raison d'etre" -- is fuel injection control. Anything that tries to replace/reprogram the PCM has to integrate itself properly into the engine management system. I'm sure that, if it's not done right, it will throw a CEL.
Here's my thinking:
Good condition, used transfer cases are somewhat hard to come by in the junkyards around here. If I'm going to rebuild it anyway, why not JUST buy the outer casing and use my internals? Saves money, that's what it does.
So, another question, how does one go about making a FI programmer compatible with a vehicle's stock ECU?
Old Apr 30, 2008 | 10:15 PM
builtfordtough13's Avatar
builtfordtough13
Jon, what were you doing on FTE during school.... tisk tisk tisk
Old Apr 30, 2008 | 11:30 PM
Bear River's Avatar
Bear River
Former ******
Here's my thinking:
You get a bama programmer. A custom FI controller on the other hand isn't compatible with the stock ECU. Rather it replaces the stock ecu completely.
Old May 2, 2008 | 10:28 AM
jg09's Avatar
jg09
Jake, shut up. Your fingers look like 'Lil Smokie sausages and you drive a pink truck.
Back on topic, however. If I do swap in an aftermarket ECU, I can imagine that a lot of the Explorer electronics won't work properly. Am I right? I've heard that Fox Body Mustangs had a very similar wiring and ECU setup and that 5.0 motor/ECU swaps aren't extremely difficult. Anybody have any experience with that?
Old May 2, 2008 | 04:44 PM
builtfordtough13
Hey now no need for insults.
Old May 6, 2008 | 10:16 AM
jg09's Avatar
jg09
Watch your mouth, boy! If you ever want help in math again, I'd change that tone!!
Oh, and good job...
Old May 6, 2008 | 05:38 PM
builtfordtough13
Good job... for what??
