General Automotive Discussion
Why do we Still Have Starters?
Old Apr 28, 2008 | 03:53 PM
Bruker's Avatar
Bruker
I spend a lot off time behind the wheel and I get to thinking about stuff...
With electronic ignition, fuel injection, crank position sensors and engine management computers, shouldn't we be able to start an engine just by injecting fuel into the proper cylinders and fire the sparkplugs?
Old Apr 28, 2008 | 04:24 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
You have to have some compression of the fuel/air mixture .
Old Apr 28, 2008 | 04:28 PM
77300i6's Avatar
77300i6
You would still need something to "start" roating the engine to draw in and compress the air/fuel so the spark plugs can ignite the air/fuel mixture as opposed to tryin to ignite a puddle of liquid fuel.
Old Apr 28, 2008 | 04:59 PM
85e150's Avatar
85e150
Why they still hang off the side down in the water/mud next to the exhaust pipe might be a better question.
Old Apr 28, 2008 | 05:32 PM
Keepin It Real's Avatar
Keepin It Real
I've thought about this myself, and I think I've come up with a better idea. Why not attach a length of stiff metal to the end of the crankshaft on the front of the engine, extend it out to the front of the vehicle with a handle on it to turn the engine over while the key is in the "on" position? This would eliminate the starter and save a lot of money, in my opinion. Who's with me?
Old Apr 28, 2008 | 06:51 PM
Eagle460's Avatar
Eagle460
You know, back in the 20's and 30's that's how the engines were started.
If you want to fire up a 460 using a hand crank be my guest, I'll stick with my conventional electric starter.
Old Apr 28, 2008 | 07:41 PM
85e150's Avatar
85e150
Originally Posted by monckywrench
"Why they still hang off the side down in the water/mud next to the exhaust pipe might be a better question."
Probably because the real estate elsewhere on the engine is occupied, and it is (theoretically...) easy to replace it there.
A Cadillac guy quoted in Hot Rod, answering the question about putting the starter in the valley between the cylinder banks, like Lexus or Infiniti, said the starters die from heat or water. Less heat and no water in there, so you'll not be needing to get to the starter..... If you could prove the "Bendix" gizmo would last as long as the protected electric motor, I think you'd be on to something. Of course, on some rigs, it might be easier to pull the intake than to pull the headers to get to the starter.
Next time I engineer a new engine from a clean slate I'll think about it......
Old Apr 28, 2008 | 07:47 PM
galaxie641's Avatar
galaxie641
Back to the good 'ol days of broken arms from just trying to start your vehicle.
Old Apr 28, 2008 | 08:08 PM
fmc400's Avatar
fmc400
MSEE
That's his point; it was a joke.
Old Apr 28, 2008 | 08:14 PM
Ford_Six's Avatar
Ford_Six
Well, if you're going to go that route-
With all the chemical technologies, why do we need to change the oil? Why do parts wear out? Why do tires wear out? Why do brakes wear out?
I think a starter isn't that bad of a failure item. I know they can be a pain to replace, but how often do you really replace them?
Old Apr 28, 2008 | 08:48 PM
MuddyAxles's Avatar
MuddyAxles
Could happen
So I was at the truck show last year and one of the exhibits shows this up-and-coming technology whereby a quite large alternator is installed (somewhere) inside the bell housing. This power supply drives all parasitic loads electrically...so your fan, water pump, oil pump, air compressor, air conditioner....everything except the camshaft was driven electrically.
It is only a small task to install electronic switching gear to make that alternator into a starter.
So, I guess it's already been done, at least on paper.
Old Apr 28, 2008 | 11:31 PM
ford2go's Avatar
ford2go
There actually was some discussion about eliminating starters. This was when they were trying out electrically acuated valves. Never went anywhere because the whole 42 volt electrical system turned out to have problems.
Thought was that with the electrical valves, they could seal seal the cylinder whenever it was close to the right position. Apparently they thought that they could get enough of a pop to get things going even without compression. Does seem tricky. I wouldn't want to rely on it at -25 ( that's F , not those wimpy C degrees).
My Dad did use one of those mechanically operated starters fairly often when we had a Model A-- wanted to 'save the battery'.He never complained that they removed that option when he got a newer car.
ford2go
Old Apr 29, 2008 | 12:35 AM
dono's Avatar
dono
Gone but not forgotten.
Pulled the starter on my Bradley today to replace the solenoid .... easy on the VW engine.
Old Apr 29, 2008 | 07:01 AM
wendell borror's Avatar
wendell borror
Just give me a hill and a manual tranny, don't need no stinken starter. When no hills are available, a strong wife works as well hee hee.
Old Apr 29, 2008 | 07:32 AM
osbornk's Avatar
osbornk
I don't think you can make an alternator into a starter motor but you can and they did make a generator into a starter. The old pre-alternator John Deere lawn and garden tractors used the generator as a starter motor. It didn't have nearly as muchpunch as a regular starter because it was belt driven. I had a 74 Suzuki GT185 motorcycle that also used the generator as a starter motor.
