largest tires to fit in stock setup?
Not even familiar with mtz's.
Offset wheels are wheels that push the centerline of the tire out.
Look Here: Wheel Tech - Offset
on a bone stock f-250 the 265 75 16's are a pefect fit. the 285 75 16's will fit but may rub a little and will fill the wheel wells up a bit more. in my opinion the 265's look and perfrom the best.
on a bone stock f-350 the 305\70\16's look and perform the best.
you can go bigger but as everyone else said you will have to get into bumper shimming.
i had a 3 inch body lift on my old 250 and 315\75\16's fit very nice. i shimmed the bumper and got 38.5\15.5\16.5's on it without rubbing.
been running 37" SSR's for about 8 months. if i am turned lock to lock with the suspension flexed it scrubs but that is few and far between. however i do not have a stock front bumper. you should be able to fit 35's with no problems
EDIT... i noticed you are talking about an F250, i wouldnt go any taller than 295's
-cutts-
-cutts-
Adventure Rider
02-01-2013 01:03 PM
