Van turbo's
Old Apr 28, 2008 | 09:53 AM
Superduty krazy's Avatar
Superduty krazy
Van turbo's
Hey guyz been busy for awhile haven't had much time to post here, I have an opertunity to get a rebuilt van turbo for 200$, what mods do i have to do to make this baby fit????? I also guess i will need to send my dp back to jody to flash it for the new turbo right...I just got beat up on by my buddies 03 cummis an he only has a 80hp chip on it...I didn't like that at all so, I figure i may as well go the next step an do my turbo , Thx for any imput in adv..
Old Apr 28, 2008 | 11:47 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Turbo is not going to help much in the case of beating your buddy. If anything, its going to make you slower, without more fuel. Looks like you need to investigate some injectors or more ICP to get some more power.
Old Apr 28, 2008 | 12:13 PM
aklim's Avatar
aklim
Van turbo will get you lower EGTs and maybe it might be more efficient. What you will need is the adapter from Beans Diesel since the EBPV part of the turbo will not fit. No reflash necessary. I talked to Jody for my case
Old Apr 28, 2008 | 01:26 PM
Superduty krazy
I was thinkin bout getting injectors but I'm not really sure what to get?
Old Apr 28, 2008 | 01:28 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Take a look at these injectors. clicky
Old Apr 28, 2008 | 01:52 PM
Superduty krazy
they look good but i will have to call someone and figure out the best route to take with this....
Old Apr 28, 2008 | 02:14 PM
Izzy351's Avatar
Izzy351
Keep in mind that if you do get injectors, you WILL need reflashed (especially if you go with Single-Shots). How bad did you get beat? The reason I ask is that once you start down this path, it gets $$expensive$$. If you go with the stage II singles, that will get you right around the 400RWHP mark. And you will likely need something done with your turbo anyway. You can get away with going to a van-style turbo at that power level I think. There was a recent thread that basically stated that not too long ago. Which really got my attention, since 400 RWHP is my goal!!. Beans actually sells the 1.0 exhaust housing and adapter (CLICKY)that will get you essentially a "van turbo", or you can get the one you have lead on and buy just the exhaust adapter for $100 (unless it's coming with one, which would be a friggin' steal!!).
If it were me, I'd jump on that van turbo deal in preparation for the bigger sticks. The Single Shots really are the way to go since you won't be forced into big oil. Go any bigger than that, and you'll have to drop another $1300 or so on something like the Pulse to supply the needed oil to the injectors. Then, you'll need a bigger turbo again...................... You see where this is going, right?
After all that, with his dumb Cummins, he can jump to the 500+HP mark pretty quickly (and cheaply) and burn you again, then you really have to get out your wallet to compete. I wish you luck!!!
Old Apr 28, 2008 | 04:56 PM
Superduty krazy
thx izzy I will be picking that turbo up....the reason i'm getting a great deal is that a friend of mine was a mech for the casino and he put the turbo on, not 3 mounths later they scaped 3 of the vans....so he told me what wreaking yard had them, i went by an they said 200$ takes i didn't have the money that day but they are holding it for me....I was already thinking about the single shots mostly beacause i wouldn't need a new hpop to run them
Old Apr 28, 2008 | 06:44 PM
totin_tools's Avatar
totin_tools
Is your 99 an early or late? It might make a difference then, I think.
Old Apr 29, 2008 | 08:21 PM
Superduty krazy
mines an early 99
Old Apr 29, 2008 | 08:46 PM
PowerstrokeJunkie
That sucks. Well, wait a few weeks for the new terminator single to be out, get that or the pulse, a set of stage two singles, a Dominator 66 and possibly a torque converter!
Old Apr 29, 2008 | 08:56 PM
jhand124's Avatar
jhand124
Originally Posted by Superduty krazy
mines an early 99
Just got more expensive, the van turbo won't be a direct bolt on even with the exhaust adapter. Different spider and pedestal.
I would pick it up anyway, buy more if there are more vans there.
Edit: You may be able to upgrade to late 99 by using the vans pedistal and spider.
See what they want for the whole shebang, let me know I would love to upgrade if I could find the parts cheap.
Old Apr 29, 2008 | 09:01 PM
Mike Norwood's Avatar
Mike Norwood
Hey, guys. I just picked up a good used van turbo for a hundred bucks. It is coming with the pedestal, but the stock exhaust flange. Did I do okay?
Old Apr 29, 2008 | 09:03 PM
aklim's Avatar
aklim
If it is working, you did well you *******.
jhand124's Avatar
jhand124
I would say that is a steal. Is the turbo in good shape?
