code 1661
Old Apr 28, 2008 | 09:39 AM
farmer ford's Avatar
farmer ford
code 1661
finally got my truck scanned. HPOP passed, contribution test passed. the only problem found was a 1661 code, and according to the tech my pcm is searching and not finding the right data. according to him i need a new PCM.
what do you guys think?
Old Apr 28, 2008 | 09:46 AM
tjbeggs's Avatar
tjbeggs
1661 PCED OCC signal low Aborts KOEO OCC test Low system voltage, internal PCM fault
Either yes your PCM is bad (doubt it!), you have a battery or alternator that isn't doing its job or he ran the test when the GP's were active and you have weak batteries. I would have the batteries and alternator tested. you could also have wiring or ground issues. Full on testing should be done before replacing the PCM. I am pretty sure this code is referring to the 5 volt reference sent out to the sensors but I can't say for sure.
Old Apr 28, 2008 | 01:18 PM
farmer ford
batteries in november but i have wondered about a ground the radio gets interference and sometimes a get static shock when getting out. i guess ill change the ground to the block and the block to the frame. any other thoughts??
Old Apr 28, 2008 | 01:19 PM
farmer ford
won't let me post rep points but once again you deserve them.
Old Apr 28, 2008 | 02:24 PM
tjbeggs's Avatar
tjbeggs
I am not sure where the PCM gets its ground but I would look there as well. Its probably up on the driverside fender but not really sure.
