Intercooler Done!!
Old Apr 28, 2008 | 09:33 AM
93f1505.0L's Avatar
93f1505.0L
Intercooler Done!!
Saturday night about 5:00 I got started on making the pipes, My nieghboor was helping sense he can weld better than I can. After a few problems with clamps and what not I was driving her at 9:30 that night. I lost a bout 5 psi on the cold side. Turbo lag is bad but I havent moved my map sensor yet.
I want to wrap the pipes in exhuast wrap. What do you guys think i should use and where is a good place to get it?
What clamp are you guys using to clamp the early 99 intake the our turbo?
My stock one broke but I got it to work. Im going to get a new one I just wanted to see if there is something better to use.
I think a have a few more questions but I forgot them right now. Ill get pics as soon as I get it done the way I want it. It doesn't look so hot right now.
Thanks
John
Old Apr 28, 2008 | 09:51 AM
tjbeggs's Avatar
tjbeggs
Once you move your MAP line you will like it better. For the clamp you need the clamp for the early 99. the y-pipe flange is wider than the OBS one so you should get the clamp from ford for the early 99.
I would not wrap the pipes. I don't think it would look good and it will trap moisture. Ceramic coating would be the way to go if you wanted.
Old Apr 28, 2008 | 10:19 AM
secondarychaos's Avatar
secondarychaos
why doesnt anyone do Air to water intercoolers? is there any big drawback i dont know of?
Old Apr 28, 2008 | 10:52 AM
tjbeggs's Avatar
tjbeggs
I think the biggest reasons there aren't many (some are used a few older HD apps, L10 cummins (atleast some) have a air to water located inside the intake mainfold) air to water is availability, cost, weight and with an air to water you have two heat exchanges that have to happen, intake heat into the water then water back out to ambient air. I think the draw backs out weight the only advantage I can think of is short tubing resulting in less lag. Also It would make me nervous to have a possible liquid leak point inside of my intake due to possible leakage and hydro locking my engine.
Old Apr 28, 2008 | 11:12 AM
secondarychaos
Thats a good point.
I've been looking on frozenboost.com, and they have generalized kits...
Old Apr 28, 2008 | 11:21 AM
tjbeggs's Avatar
tjbeggs
I looked at those kits when you mentioned them in another thread but the problem is I am not sure if they flow enough air. Do they recommend one of the kits for the PSD or have flow numbers somewhere?
Old Apr 28, 2008 | 11:55 AM
secondarychaos
Ya, on the specific information part it recommends sizes by minimum CFMs
Old Apr 28, 2008 | 11:56 AM
secondarychaos
And i would think that if you get to the next one's CFM rating, you need to move up. just my educated guess. they also dont have the best customer service dept.
Old Apr 28, 2008 | 12:04 PM
tjbeggs's Avatar
tjbeggs
You would have to go with this kit
Water to Air Intercooler
You would also still need custom tubing, and intake Y. Still not really sure where the cooler would go. Probably room over the passenger VC. extra electrical draw on the alt from the fans. I don't know. I think it could be a good setup its just new ground. If would be just as much work to install and could still end up costing close to $700 depending on your fab skills and parts hunting skills.
Old Apr 28, 2008 | 01:03 PM
secondarychaos
Ya, it's definately something that would take time.
I just remember your Intercooler job, and saying how bad the lag and boost drop was.
Maybe i'll be the one to break that ground.
Hard to decide between the 600 and 1200...
Where's the middle ground? I think the reason they state the minimum CFM is to avoid the chamber effect...
Old Apr 28, 2008 | 02:22 PM
tjbeggs's Avatar
tjbeggs
Stock turbo is rated at 750 CFM so I would not go with the smaller unit
Old Apr 28, 2008 | 02:55 PM
93f1505.0L's Avatar
93f1505.0L
I just called ford about that clamp they want 30 bucks for it. Kinda pricey but I have to have it. I was kinda ify on the wrap part but I think ceramic is probaly out of my price range. I might paint if I don't wrap them.Does 5-6 psi sound like a lot to lose from this. I think I might have a leak somewhere. What would be the best way to check for one?ThanksJohn
Old Apr 28, 2008 | 03:21 PM
tjbeggs's Avatar
tjbeggs
yes 5-6 psi does seem high. I lost about 3 psi. I can still hit my peek of 33 it just takes more throttle longer to hit it. best way to check for leaks is to pressurize the system with 10-15 PSI air pressure. You can do that by building a cap that clamps into the intake tubing pre turbo and using a mini regulator to regulate the pressure you put to it. Here is an example
Dieselsite Turbo Boost Leak Detector - 3"
Old Apr 28, 2008 | 03:34 PM
93f1505.0L's Avatar
93f1505.0L
Thanks TJ. I think making one will be a bit cheaper than the 60+ for that one. The most boost I have now is 15. I hit 24 at one time then I did the eot mod and it went to 20. The guage bounces a lot though but 24 was in the middle of the bounce. I hope the leak isnt in the ebay intercooler that was in "perfect running condition with no leaks". That will make me pretty mad.
Old Apr 28, 2008 | 04:06 PM
secondarychaos
What if you made the Water-air unit the low spot in the tubing? would that prevent hydrolocking in the event of a leak?
