Aerostar Ford Aerostar
Strange clutch problem....
Old Apr 28, 2008 | 08:43 AM
Pablo-UA's Avatar
Pablo-UA
Got air in clutch.
Bled clutch. All was good for a week, then problem appeared againe.
I have no leaks, all look fine. I think it may be ready to fail MC.
Your suggestions?
Old Apr 28, 2008 | 08:06 PM
93nighthawk's Avatar
93nighthawk
I agree, sounds like the MC if you cannot find any other leaks.
Old Apr 29, 2008 | 12:40 AM
Pablo-UA's Avatar
Pablo-UA
No leaks.I'm surprised
Old Apr 29, 2008 | 12:42 AM
marty600's Avatar
marty600
My vote = MC, had the same thing happen years ago, replaced it, and problem went away..it's a simple system, not too much to diagnose, it's 1 of 2 things gone bad!
Old Apr 29, 2008 | 03:38 AM
Pablo-UA's Avatar
Pablo-UA
My MC is under the hood, not inside cabine, becouse I converted my aero to manual tranny using brake pedal unit and may be that's why I can see no leaks. Well, just bled cluth. All work fine. I gonna replace MC is problen will go back.
Old Apr 29, 2008 | 05:12 AM
Aeroman59's Avatar
Aeroman59
If MC is bad .....what happens when you depress clutch pedal for ,say 30 seconds, & then try to put into gear? if so piston seals/bore are leaking.
Old Apr 29, 2008 | 06:29 AM
Pablo-UA's Avatar
Pablo-UA
Now all work well. After 2-3 minutes I can easily put into 1 ore 2nd. No leaks
Old Apr 29, 2008 | 04:16 PM
pinceau's Avatar
pinceau
I had this problem on my Peugeot 504 diesel, the culprit was the slave cylinder sucking air: the aluminium piston was rusted by the winter salt; and strangely they were no leak.
Old Apr 30, 2008 | 12:37 AM
Pablo-UA's Avatar
Pablo-UA
I rebuilt my slave today. not sure this rebuild kit helps, but it was got for free.
